[geos-devel] Re: [GEOS] #238: Internal error: 7 ERROR: GEOS union()
threw an error!
geos-trac at osgeo.org
Fri Mar 13 10:27:07 EDT 2009
#238: Internal error: 7 ERROR: GEOS union() threw an error!
Reporter: julich | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 3.1.0
Component: Default | Version: 3.0.3
Severity: Unassigned | Resolution:
Keywords: |
Old description:
> When trying to merge several geom using ST_Union() function, I sometimes
> get an exception / internal error:
> SQLSTATE[XX000]: Internal error: 7 ERROR: GEOS union() threw an error!
> Here is the SQL query (which perfectly works on thousands of other
> ST_Union() I did using the very same method) :
> SELECT
> ST_SetSRID(ST_Multi(ST_Union(place_geom)), 4326) AS place_geom
> FROM
> geo_place
> WHERE
> place_id IN
> (3169600,3169596,3169647,3169665,3169562,3169564,3169595,3169597,3169598,3169618,3169619,3169648,3169674,3169675,3169676,3169677,3169649,3169599,3169604,3169605,3169633,3169634,3169635,3169650,3169658,3169678,3169563,3169567,3169569,3169575,3169565,3169561,3169615,3169616,3169617,3169672,3169607,3169620,3169668,3169669,3169670,3169673,3169566,3169585,3169588,3169601,3169602,3169603,3169606,3169659,3169664,3169651,3169591,3169632,3169637,3169638,3169703,3169636,3169662,3169663,3169568,3169570,3169574,3169559,3169560,3169518,3169594,3169625,3169671,3169630,3169586,3169587,3169584,3169589,3169581,3169709,3169720,3169705,3169504,3169505,3169507,3169508,3169509,3169510,3169517,3169519,3169520,3169521,3169522,3169542,3169544,3169549,3169554,3169556,3169557,3169609,3169627,3169657,3169624,3169628,3169629,3169583,3169710,3169707,3169721,3169506,3169626,3169536,3169537,3169538,3169539,3169543,3169545,3169546,3169547,3169548,3169550,3169551,3169553,3169555,3169558,3169511,3169512,3169513,3169514,3169515,3169516,3169540,3169541,3169610,3169656,3169704,3169706,3169708,3169801,3169803,3169804,3169579,3169623,3169531,3169532,3169533,3169552,3169525,3169530,3169593,3169654,3169655,3169700,3169722,3169802,3169701,3169876,3169877,3169878,3169880,3169577,3169879,3169576,3169534,3169526,3169527,3169503,3169523,3169535,3169798,3169799,3169702,3169872,3169875,3169578,3169582,3169498,3169499,3169500,3169501,3169502,3169524,3169528,3169529,3169571,3169572,3169871,3169874,3169895,3169896,3169903,3169897,3169873,3169573,3169580,3169590,3169894,3169898,3169899)
> And here is the dataset of polygons I am trying to merge which generates
> this internal error:
> place_id;place_geom
> 3169498;0106000020E6100000010000000103000000010000000C000000D0A2090C051002403F2CCCD71E784840F11D1696AD0F02403ECC11011F7848402155F398450F0240441EE9FF1E784840EDFCBA1C2C0F02405618277C1C784840BEE265E81F0F0240ADEE522C1B784840AF5740263F0F0240F77C7DB31978484060C1E56FF10F02407599E3DF10784840CC933FF7FE0F02403652E6C710784840412E58710210024067AE738A1778484020342A3F03100240ED5DE2AE197848408B15ED82041002402C1727661D784840D0A2090C051002403F2CCCD71E784840
> 3169499;0106000020E6100000010000000103000000010000000A0000000D01ABFC9A100240250F76AE1E784840D0A2090C051002403F2CCCD71E7848408B15ED82041002402C1727661D78484020342A3F03100240ED5DE2AE19784840412E58710210024067AE738A17784840CC933FF7FE0F02403652E6C7107848407AFE2F8D6A100240489577061078484012488D6C93100240A1F3FDBC0F7848404D12A99E97100240A643D034197848400D01ABFC9A100240250F76AE1E784840
> 3169500;0106000020E6100000010000000103000000010000000A000000B12BFC222F1102401B00A98F1E7848400D01ABFC9A100240250F76AE1E7848404D12A99E97100240A643D0341978484012488D6C93100240A1F3FDBC0F784840D4F8F661E510024061989A340F784840A44376E52811024068DBCA061178484058757669291102407D961D4413784840A5270D7A2C1102406E923A65197848400434E1622E1102409E16811C1D784840B12BFC222F1102401B00A98F1E784840
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
> 3169503;0106000020E6100000010000000103000000010000000C0000000C152E19D91202406C4E8E050E78484046398BB337130240EAF29D40117848405D9E8B7D3C1302402839393217784840F0944FFC3D130240F76DAC5B1A784840C47B951C401302407B6B290C1E784840EABBC4868412024088D2A3391E784840C800C5B383120240B1C618DA1C7848401CBA748181120240AD80D1221978484077F91F5E81120240DF02C4EE1878484002A1193B7F1202406376FAD8127848403937996D7E12024045876C9F107848400C152E19D91202406C4E8E050E784840
> 3169504;0106000020E610000001000000010300000001000000040000000A2E69236C1902403D6F0147DC774840528B95379A19024061066B8DE8774840F3E66D96FE180240FF2E6688E17748400A2E69236C1902403D6F0147DC774840
> 3169505;0106000020E6100000010000000103000000010000000A000000BC883198E7180240569CABC85278484045B5AE90E2180240E509CE9553784840C8F7A52FBA1802401AA870095A784840F1E49B58A6180240595F039A5D784840AFC0734393180240FC810B725F784840B53D5C0541180240E1D8B59368784840059F5F5C3D180240074B87FC68784840ED2355A2011802409BACBB8567784840C24A6A61C51802402CB2E2DE55784840BC883198E7180240569CABC852784840
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
> 3169507;0106000020E61000000100000001030000000100000005000000420E100B761902407791691C37784840583D82B16619024094DE7B7C3B78484049B64024BC180240A3712795387848404410573905190240168FED3635784840420E100B761902407791691C37784840
> 3169508;0106000020E61000000100000001030000000100000006000000FFC25F1B7E1902408BE14C1F35784840287CC679761902400DADFAFB36784840420E100B761902407791691C377848404410573905190240168FED3635784840E37353D528190240F735239633784840FFC25F1B7E1902408BE14C1F35784840
> 3169509;0106000020E61000000100000001030000000100000005000000F3F0259684190240FDCD028833784840FFC25F1B7E1902408BE14C1F35784840E37353D528190240F735239633784840DA94CFE942190240539BE46432784840F3F0259684190240FDCD028833784840
> 3169510;0106000020E610000001000000010300000001000000040000004B7B2F5299190240437570712E784840F3F0259684190240FDCD028833784840DA94CFE942190240539BE464327848404B7B2F5299190240437570712E784840
> 3169511;0106000020E61000000100000001030000000100000007000000C3E954995B160240DE31D633D27748400C67907CF615024009C804BDD4774840B3020170D915024029AABBADCE77484080CDDFF2D515024010341FF4CD774840AC0FADD81616024099FAB585CB7748405A59B45A3B160240D8C7C01ECB774840C3E954995B160240DE31D633D2774840
> 3169512;0106000020E61000000100000001030000000100000008000000A177E968D4160240673CECFECB774840AAE8E7B8DF160240DDE18CB3CE7748403B2455B88A1602407407B3EDD0774840C3E954995B160240DE31D633D27748405A59B45A3B160240D8C7C01ECB77484065617E898F160240E2E4C732CA7748404901EF4ECA160240050B2685C9774840A177E968D4160240673CECFECB774840
> 3169513;0106000020E610000001000000010300000001000000050000001421F200A31502401C36D27AD077484015894ADEA015024017ACDA02D077484080CDDFF2D515024010341FF4CD774840B3020170D915024029AABBADCE7748401421F200A31502401C36D27AD0774840
> 3169514;0106000020E610000001000000010300000001000000050000000C67907CF615024009C804BDD4774840A248D78EBC1502408A59D80CD67748401421F200A31502401C36D27AD0774840B3020170D915024029AABBADCE7748400C67907CF615024009C804BDD4774840
> 3169515;0106000020E610000001000000010300000001000000060000001421F200A31502401C36D27AD0774840F83E59F07015024066B13C22D2774840BF0348703C150240FBB480DFD3774840F4C06414551502400EFA28F5D277484015894ADEA015024017ACDA02D07748401421F200A31502401C36D27AD0774840
> 3169516;0106000020E61000000100000001030000000100000008000000143A790D98180240E4C3B20CCF774840EF57A444FB170240E0933077CE77484014BA7E62C4170240F1E3F12ECE774840A177E968D4160240673CECFECB7748404901EF4ECA160240050B2685C977484019A49614F817024011652A1FCD77484041B9482272180240F912E69BCE774840143A790D98180240E4C3B20CCF774840
> 3169517;0106000020E61000000100000001030000000100000005000000F78E468CAE1A02406A872ED11D784840875ED297AE1A0240527A63EE1B784840A97265411A1B024059C2D4EF177848400A90F8CA171B0240D7C7512A1C784840F78E468CAE1A02406A872ED11D784840
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
> 3169519;0106000020E6100000010000000103000000010000000D0000007B54BFC1EF18024085AC2CB8BE774840C22B747A451902403523943BBF7748407BBBC3D54519024038F9A647BF77484075A8EE8652190240C296A133C1774840CC06D7A293190240472767B7CA774840C8381CCEAE1902404FA569C0CE7748409BEE59EFA7190240CD2696BFCE774840D9441CA5A51902406CE8CEBECE774840604EF7B5A2190240DA0EC7BECE7748404F3D9EE75519024014704472CF774840F9287276371902409B1BD3A2CA774840B73BBAD4101902401C98962AC47748407B54BFC1EF18024085AC2CB8BE774840
> 3169520;0106000020E6100000010000000103000000010000000F00000072FD5481911A02409B01987BCF7748406997A76E1B1A0240CB85CE19CF774840279998BE0C1A0240B5A948D3CC774840DC373557021A0240B8E6ECF7CA774840A93D9AEBE31902407E395E3CC577484095FBFA9DCE190240759ED24DC1774840084D3F91C51902404EF294AFBF7748405780047FC5190240382BCFABBF7748407896FAB5C519024023BECFABBF7748400C0C49DB131A0240034D85C5BF77484090970D22191A024029718493C077484099F6373A5E1A0240629C0511CB774840C39A788D6E1A0240A01398B3CD774840A73614E48A1A02404DB438C2CD77484072FD5481911A02409B01987BCF774840
> 3169521;0106000020E610000001000000010300000001000000040000007B1237EB941A02404EE8B561D077484072FD5481911A02409B01987BCF774840791CAD7BAC1A02403420C091CF7748407B1237EB941A02404EE8B561D0774840
> 3169522;0106000020E6100000010000000103000000010000000900000072FD5481911A02409B01987BCF774840A73614E48A1A02404DB438C2CD774840C39A788D6E1A0240A01398B3CD77484099F6373A5E1A0240629C0511CB774840E19FC1EA9E1A02407C096D43CE774840C889D1FFAD1A024094F43003CF774840CCEAF100B41A024098A7B04ECF774840791CAD7BAC1A02403420C091CF77484072FD5481911A02409B01987BCF774840
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
> 3169526;0106000020E6100000010000000103000000010000000D000000D43CA05C851002403C0F4E7F0B784840BB8EED6E8510024031610F800B78484081AD16D9AD1002402EB7108409784840BDF92D18FB100240179F08B7057848401F032EDA4B110240424640B8017848407C0358E04311024066A11A29007848408C260DFCA9110240761FF5B1037848405EFE0202C011024052A3557604784840D39A66C734110240402A314D0B784840D4F8F661E510024061989A340F78484012488D6C93100240A1F3FDBC0F78484099B7B06F88100240155BC29C0B784840D43CA05C851002403C0F4E7F0B784840
> 3169527;0106000020E610000001000000010300000001000000090000007C0358E04311024066A11A29007848401F032EDA4B110240424640B801784840BDF92D18FB100240179F08B70578484081AD16D9AD1002402EB7108409784840BEA849818510024019598D7E0B784840BB8EED6E8510024031610F800B784840D43CA05C851002403C0F4E7F0B784840BDC2D0D66E100240214ED5AB0A7848407C0358E04311024066A11A2900784840
> 3169528;0106000020E61000000100000001030000000100000008000000D43CA05C851002403C0F4E7F0B7848408F2423995F1002406033A55B0D7848407AFE2F8D6A1002404895770610784840CC933FF7FE0F02403652E6C71078484060C1E56FF10F02407599E3DF10784840E73CFA28F40F02403B0FF9BD10784840BDC2D0D66E100240214ED5AB0A784840D43CA05C851002403C0F4E7F0B784840
> 3169529;0106000020E610000001000000010300000001000000070000007AFE2F8D6A10024048957706107848408F2423995F1002406033A55B0D784840D43CA05C851002403C0F4E7F0B784840BB8EED6E8510024031610F800B78484099B7B06F88100240155BC29C0B78484012488D6C93100240A1F3FDBC0F7848407AFE2F8D6A1002404895770610784840
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
> 3169531;0106000020E6100000010000000103000000010000000A0000001A35FC4F951402400735526C22784840ED182693571302405E7634A02F784840B38CB469F8120240E5EB79C72B78484013B58122E3120240559FCCA82C7848401AF7B7C135120240AE6F0AA825784840DD17A8BF341202403B3D3010237848404639DB956E1302404A6699BA22784840B823BAACBF1302402763D9A42278484005B8DC9A2C14024074EBDA87227848401A35FC4F951402400735526C22784840
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
> 3169537;0106000020E61000000100000001030000000100000008000000BFDE8D5FC3130240A6F714395478484055D54B53FA130240A0E545ED51784840A2D5CAAFFB130240FD5233DE517848406481A9EB6214024056591894537848408DECED8F53160240344456CE5B784840B7C31A4B3716024016177DA45E784840BF5000F72A14024088BB3EF155784840BFDE8D5FC3130240A6F7143954784840
> 3169538;0106000020E610000001000000010300000001000000090000005B7A4CAA0212024065A7BF1E4A7848400A89F07CC811024096FD7E924C7848406470D48EC71102409DE7778F4C7848407F0A3EB9FA100240D92BCBBC49784840E5511882F91002401EBDF4AF497848409B30E72D801002403FC18FC0447848402E3E2B25C31002408973EDAE4578484012978C1E0B110240D9B1B2AE467848405B7A4CAA0212024065A7BF1E4A784840
> 3169539;0106000020E6100000010000000103000000010000000D000000A2D5CAAFFB130240FD5233DE5178484055D54B53FA130240A0E545ED51784840BFDE8D5FC3130240A6F714395478484078E7CD6ACE12024016D26828507848400A89F07CC811024096FD7E924C7848405B7A4CAA0212024065A7BF1E4A78484057082A2C0712024082E5642F4A784840E19EC1EA45120240D3AC68154B7848407A829215D9120240A157E1304D784840C68FFCB657130240519628274F7848407D229A16BD130240F54EBDD4507848409897A27AD2130240BFD17E2F51784840A2D5CAAFFB130240FD5233DE51784840
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
> 3169541;0106000020E6100000010000000103000000010000000D000000657E435B241402400E125665DE774840E8EEAF71D914024054F7E68ED7774840C4C6FDE8EF140240F69F7DA9DA7748405A856612BF1402409E150BE5DB774840D56CE5EAA01402400C53F9E8DC774840EBEEC8997B140240E035EE29DE7748406EFDE4EB57140240DDECE6C0DF774840F6E73BE621140240B6D83A39E2774840E0FD5A9FF8130240183F0C6DE4774840E3CEC69FBA130240B7DE302EE87748403AFA9B357413024031591413E5774840BAF9208CB8130240CE18C582E2774840657E435B241402400E125665DE774840
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
> 3169543;0106000020E61000000100000001030000000100000005000000076CD2F91C0D024040B2045144784840DB8D9FC2B20D0240FA14CA484A78484086375E07C60D024016CEEB6B4C7848400CB59893130D0240ABAB413945784840076CD2F91C0D024040B2045144784840
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
> 3169546;0106000020E610000001000000010300000001000000050000000A89F07CC811024096FD7E924C7848407562D2C88511024028C371644F7848407F0A3EB9FA100240D92BCBBC497848406470D48EC71102409DE7778F4C7848400A89F07CC811024096FD7E924C784840
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
> 3169548;0106000020E610000001000000010300000001000000090000007562D2C88511024028C371644F7848400A89F07CC811024096FD7E924C78484078E7CD6ACE12024016D2682850784840BFDE8D5FC3130240A6F7143954784840716F1303C2130240ED6A66475478484029860F61F1120240DEAEC9FB5C784840658764E1C81202406BDD39905C7848408A16DD0B9612024086F1CE755A7848407562D2C88511024028C371644F784840
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
> 3169550;0106000020E6100000010000000103000000010000000D0000006B9E64E6CD160240A19D4E84207848409364680BCF160240868E998920784840EE68CA5C13170240CF4A63C32178484008E0791518170240598A50D921784840244DFC0971160240C9D7C701227848409C7A16BA63160240081169052278484079C361D958160240524981FE21784840E6A8ECFC7D1502402A2D322D227848406BF61D943F1502401642E03D2278484071E419D33E150240F09EE0E520784840369836D33E150240D3EA59E12078484011021EB8751502403502DFD5207848406B9E64E6CD160240A19D4E8420784840
> 3169551;0106000020E6100000010000000103000000010000000900000008E0791518170240598A50D921784840EE68CA5C13170240CF4A63C3217848409364680BCF160240868E9989207848406B9E64E6CD160240A19D4E84207848405CEA8F40C8170240DB021B4920784840DE4AB55D6B190240279772EB1F7848403A530182571902409A2A905121784840A07EC2DCC81702409038EDAD2178484008E0791518170240598A50D921784840
> 3169552;0106000020E61000000100000001030000000100000009000000D5228EAA62160240EF5390961E7848406B9E64E6CD160240A19D4E842078484011021EB8751502403502DFD52078484071E419D33E150240F09EE0E520784840369836D33E150240D3EA59E1207848400C48FBBA3D15024028BD12D81E784840DA4877A2791502402304E0C81E784840D7FE167361160240F1008D961E784840D5228EAA62160240EF5390961E784840
> 3169553;0106000020E6100000010000000103000000010000000A0000006B9E64E6CD160240A19D4E8420784840D5228EAA62160240EF5390961E784840ACD93803C7170240AB22634A1E78484036EB83085F190240655216E81D7848401009281170190240AE23FCE21D7848400C111A1170190240BE7D3FE51D784840DE4AB55D6B190240279772EB1F7848405CEA8F40C8170240DB021B49207848409364680BCF160240868E9989207848406B9E64E6CD160240A19D4E8420784840
> 3169554;0106000020E6100000010000000103000000010000000F000000DE4AB55D6B190240279772EB1F7848400C111A1170190240BE7D3FE51D7848401009281170190240AE23FCE21D784840230101609F190240308F25D51D7848407639C842AE1902408BF712D91D78484002EA90F2C4190240A87297DE1D784840F32A045DE31902405AE473E61D78484053C0F6AE1A1A0240052F6AFE1D784840C7B0DA2D3C1A0240EEA9A8EC1D7848405B8B0BFD391A0240B44B14BE1F7848403849F3FD201A0240365F7F8920784840107D4CE91F1A02405F5AADD52078484096EA165F0F1A0240A7CD3826217848403A530182571902409A2A905121784840DE4AB55D6B190240279772EB1F784840
> 3169555;0106000020E6100000010000000103000000010000000C000000D5228EAA62160240EF5390961E784840D7FE167361160240F1008D961E784840233AA1591F160240AA364F611D78484062AEA77ACB1702406E4EA7161D7848403CC417378A180240B78F82D21C78484091DC353560190240AFB909AF1C78484041A73DE2701902403A95EEA91C7848401009281170190240AE23FCE21D7848400C111A1170190240BE7D3FE51D78484036EB83085F190240655216E81D784840ACD93803C7170240AB22634A1E784840D5228EAA62160240EF5390961E784840
> 3169556;0106000020E610000001000000010300000001000000070000000C111A1170190240BE7D3FE51D7848401009281170190240AE23FCE21D78484041A73DE2701902403A95EEA91C7848408295F2B8AF190240F8D6BA971C7848407639C842AE1902408BF712D91D784840230101609F190240308F25D51D7848400C111A1170190240BE7D3FE51D784840
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
> 3169563;0106000020E610000001000000010300000001000000A70000003A7F8B1FE6230240D4D6CB3EB87848405C85D14BE52302407D49F0D3B67848409046F520DE230240481C16E6B0784840DAF1DC8EDE230240C16A99E7B078484071C0296BE023024006C424ECB0784840E3387247E2230240433B71F1B0784840AC5FC323E423024062763BF5B07848409A406712E623024031DF05F9B07848408768B8EEE7230240341AD0FCB07848403BA160DDE9230240DA64D9FFB0784840C920B6B9EB230240B581E202B1784840E3B062A8ED23024034AE2A05B17848405C410F97EF230240A4DA7207B17848408C28C085F1230240FEE8F908B178484056561E62F32302408EC9800AB17848403E94D350F5230240C0B9460BB178484046D2883FF7230240E2A90C0CB17848406C103E2EF9230240F499D20CB1784840C0A4F71CFB230240ED6BD70CB17848401B8FB50BFD230240D01F1B0CB1784840597973FAFE230240A2D35E0BB1784840796331E9002402406687A20AB1784840B1E9A0C50224024060EF2409B17848404E2963B404240240FE84A707B17848406BBE29A30624024083FC6805B17848402A53F09108240240F7732A03B17848409183686E0A240240A79F2A00B17848401F6D335D0C240240F5F82AFDB07848401DF2AF390E24024080066AF9B07848401D307F2810240240A841A9F5B078484056090005122402400B3127F1B0784840E3E180E1132402406120A5ECB0784840C2B901BE15240240A80F23E8B078484029E6869A17240240DBE0DFE2B0784840E966107719240240F593DBDCB0784840C5E699531B2402400147D7D6B078484041ACD01D1D24024057CCD2D0B07848404D7F5EFA1E2402403D610DCAB0784840E89799C4202402406FC847C3B07848406704D98E222402408B11C1BBB0784840D16F1859242402409C5A3AB4B078484024DA5723262402409AA3B3ACB0784840BFDE48DB27240240E1A06BA4B07848402FF090A529240240BBAD629BB07848406CF2815D2B240240E5AA1A93B0784840A09C7B152D240240F96B5089B0784840B9371EBB2E240240651D4780B078484049DF1773302402405DDE7C76B0784840B520C31832240240A253F16BB0784840BB606EBE33240240D9C86561B07848405A9F196435240240073EDA56B0784840802372F73624024087854E4CB0784840C107269D382402408FBE4040B07848403DDD82303A240240F3E7F334B07848406305E4C33B24024046F3E528B07848400E73F2443D240240EFD0D71CB07848404A3305C63E24024088900810B0784840FE9D1347402402401D6EFA03B078484013AF2AC8412402409D0F6AF6AF784840D8B1EA36432402407AA19AE9AF784840F606AFA5442402404A150ADCAF7848404EAE7714462402400B6BB8CDAF7848408E47E970472402402EB127C0AF7848400C335FCD4824024042D9D5B1AF7848409E70D9294A24024047E3C2A2AF7848405AA0FC734B240240AFDD7094AF784840302224BE4C2402400BBA5D85AF7848408A3DFDF54D240240C34A8975AF7848403DBC24404F24024011277666AF7848407AD4FD7750240240B9B7A156AF784840D432849D51240240C31ACD46AF7848401BE30EC352240240C35F3736AF784840DD9199E853240240BAA4A125AF784840163F240E55240240AEE90B15AF784840A3325C215624024002017604AF784840ECBF452257240240B9CC1EF3AE7848408DF82A23582402406FB688E2AE7848400F831424592402401C8231D1AE7848405A5F02255A240240BE2F19BFAE784840222F99135B240240CDCDC1ADAE784840E598E1EF5B2402403C20A99BAE78484066012ACC5C240240AA729089AE784840A66872A85D24024013C57777AE784840A4CEBA845E24024077175F65AE784840C5CEB44E5F240240431E8552AE78484024165C066024024076F7AA3FAE784840675C03BE60240240A6D0D02CAE78484093A1AA7561240240D6A9F619AE7848403E2EFF1A6224024070551C07AE784840DD0C58C06224024002E380F3AD78484040E05953632402400661A6E0AD784840A40560E66324024004C10ACDAD784840F3721367642402406CF36EB9AD78484074DFC6E764240240D625D3A5AD7848402D4B7A68652402403F583792AD7848400FFFDAD665240240125D9B7EAD78484052FBE832662402405534FF6AAD784840CD49FB8E6624024092EDA156AD784840EA4409EB66240240D3C40543AD78484072DBC834672402407C50A82EAD784840B81E847E672402402CFA0B1BAD784840A4FDF0B5672402404458AE06AD78484034DC5DED672402405DB650F2AC7848401AB1731268240240EA04B4DEAC78484085D88D3768240240723556CAAC784840B1FFA75C68240240FA65F8B5AC784840DEB91C5D682402405F3B9AA1AC7848405D2AE46F68240240543E3C8DAC78484079E4587068240240BA13DE78AC78484060E87A5E682402408FBB7F64AC784840A499984C682402406B81E250AC784840C89DBA3A682402403E29843CAC784840FDEB89166824024085A32528AC7848406E3A59F267240240CC1DC713AC78484031D3D5BB672402407D6A68FFAB78484085194E856724024036D5CAEBAB7848402FFD773C6724024058F46BD7AB7848404DE1A1F36624024079130DC3AB78484066BD74986624024012236FAFAB784840149A473D66240240A532D19BAB7848408D14CCCF65240240A4F67187AB784840E93C4C6265240240A5D8D373AB784840ED65CCF464240240A7BA3560AB7848403DDAF97464240240176F974CAB784840FB99D4E263240240F1F5F838AB784840BE07AB5063240240D19A1B26AB78484047C985BE62240240AA217D12AB7848409983091A62240240F4989FFFAA784840DD9191756124024036F200ECAA7848401999C2BE60240240EE3B23D9AA7848406CA1F307602402409D8545C6AA784840D15720515F24024052ED28B4AA7848405EADFE875E2402406D094BA1AA78484011B1D8BE5D24024088432E8FAA7848401B0160E35C2402400D50117DAA7848406652E7075C2402408F5CF46AAA7848403EF01B1A5B240240783BD758AA784840738F502C5A2402405F1ABA46AA78484035282E2C59240240B1E95D35AA784840E9765E3E5824024096E60124AA784840EE5DE92B572402404688A512AA78484097A7C22B5624024092750A02AA78484087914D19552402403C17AEF0A97848403E7581F4532402404DA912E0A97848401B07B1CF52240240605938D0A9784840D9EDE4AA512402406AEB9CBFA9784840A8821486502402406F9BC2AFA9784840C364F14E4F240240D81DE89FA9784840C44077054E240240A590CE90A9784840FC2554CE4C2402400213F480A97848402005DA844B240240C185DA71A978484028DE08294A240240E5E88163A97848406FC08EDF48240240955B6854A97848409D9CBD8347240240ABBE0F46A97848404EA7F7DE36250240861C1FC5A87848408219488D372502408F27B255AA78484016DF786D362502405E090E9CAC7848406F1616E4332502406840E106AE7848409CA0781F2E250240B7435FEAAF784840F1B4020D2425024014C6F53BB2784840CBB931CE1E250240B8518426B3784840D1FD4E380D2502408494A560B578484046E1834AFC2402400A22740BB7784840FE36954FEE24024020B91914B87848407EAB9943B8240240DFFE139FBB78484045B22E7AEB230240612AFF0EBC7848403A7F8B1FE6230240D4D6CB3EB8784840
> 3169564;0106000020E610000001000000010300000001000000150000009D9CBD8347240240ABBE0F46A97848405AC515A9262402408A845656A978484032E03317222402408491D8A8A5784840EE03B490182402408113395B9C78484090C495610E2402407FE34EB493784840D8A0A87903240240B10C0D558B78484021B82D62FA230240BCAFECDA81784840E4694393F0230240442C5A6B78784840F41F8135E52302403185ED3F6E784840A94FB2E1F3230240A26D8B3B6E7848409FBC990BF5240240E1EFA3F86D7848400FBB4A33FD240240E46F01947478484045B90F9609250240BD34640A7E784840ED93C3C013250240FA2C488587784840E0B494EB1D250240078D66FC9078484005A714E0282502407229006F9A7848401831662F2B250240151FFDC59C7848408540DE0330250240858B43A7A1784840B2B4B5F93125024062B9719EA37848404EA7F7DE36250240861C1FC5A87848409D9CBD8347240240ABBE0F46A9784840
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
> 3169566;0106000020E61000000100000001030000000100000006000000D179C8B43C2C0240CFD452926A784840B9C53DD1352C02405ED67EA7647848403F6D4A37FA2C02405D9393586478484001290DC7DC2C02403D7EE56A657848406E63EB81442C0240722965926A784840D179C8B43C2C0240CFD452926A784840
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
> 3169568;0106000020E61000000100000001030000000100000005000000B76B7F576E2102403C5E802BAB7848403F7B25806622024090E84EBEAA784840F59D3E506E2202403BDD29B5B3784840685A8215762102408B49B508B4784840B76B7F576E2102403C5E802BAB784840
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
> 3169574;0106000020E61000000100000001030000000100000007000000EB71AAC41221024091DA25D6B578484054C99EC4782102402A940E9AB5784840F1D20664802102405E33FD6FBD784840E890B84686210240BC6445FDC2784840D34210581E2102404034C82EC37848401585A11B19210240490C706ABD784840EB71AAC41221024091DA25D6B5784840
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
> 3169577;0106000020E6100000010000000103000000010000000B000000B0E3DD90B33F0240DC5CEF50DF7848406FD94C58363F02408BCEF940D9784840186420DBBF3F024020826C9CD4784840972E27290741024090D81764C9784840A33438EDC742024058F6F4FBB9784840DB8D2D5FBC420240140AFFC1BB784840891DC2EE6C42024072935B61C7784840A1FF1A65D9410240ACF61D89CC78484081BFE35C6141024074CE907FD07848402277271C644002409D8A3C5CD9784840B0E3DD90B33F0240DC5CEF50DF784840
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
> 3169581;0106000020E6100000010000000103000000010000000C00000000781BC0FD3202407E58732ED17848402849E3F394330240DAFEFEF0CB784840993C2141EC3402403427E3EBBF7848405ECA74438C350240D048045DBA7848405338A761B73502407B6ACA7EBC784840B5FCC93FC1350240DB92DAFCBC78484091B077A7B83502401BE67A4ABD78484051E6DEE1B934024068FAE148C6784840039FED9AD333024052F8DA59CE78484011F3F6F435330240B7D30FCCD37848407E2066DB1C33024031631DA1D278484000781BC0FD3202407E58732ED1784840
> 3169582;0106000020E6100000010000000103000000010000000B0000009E46D4ECC3350240DD56175BDC784840800818E6AC35024015B98844DB784840A414CE4D9835024013D9A94ADA784840F35B37818C35024024DBFCBBD9784840DEB14CC6A03502400776210AD97848402508EB5269360240506A1D25D2784840886463E569360240E898272BD278484061CBC619A0360240599C6BBDD4784840A1B0583FEB3502403BE3E8FEDA78484071C0017CD93502403E91AA9BDB7848409E46D4ECC3350240DD56175BDC784840
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
> 3169587;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
> 3169589;0106000020E6100000010000000103000000010000000700000055F8D175B1300240C7D5B3EF72784840D7FD584FE33002404A9C503271784840D4A0F75A123102403DF789997378484042A264ED123102408E6F16A173784840BFED6494E13002400DD9E65075784840347637D7C8300240FBF79E177478484055F8D175B1300240C7D5B3EF72784840
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
> 3169593;0106000020E61000000100000001030000000100000005000000A40E467D361F024076765146AA774840916003A7851F02406E04F6AAA9774840B46815BFC61F024031DEC6FFAD77484012876A765F1F0240B70762C4AE774840A40E467D361F024076765146AA774840
> 3169594;0106000020E61000000100000001030000000100000005000000BE701275541B0240BBEC063C1D7848407305800A551B02403ACB16C41C7848402F6D1DD98D1B0240E35B18851A7848406AA30FDC8F1B024068E8D9351D784840BE701275541B0240BBEC063C1D784840
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
> 3169607;0106000020E6100000010000000103000000010000000D00000018605B10231C0240C25BEBA414784840A75D4259181D0240F5A24F9D0A784840727AD536B11D0240158CBC9F04784840AC8F4094B61D02405FFB74BC047848406C66E76C021E024009B2F46F087848404F973D69041E0240EADC2037097848404165542D071E0240A1EB7F4A0A784840B226CA27071E02406BBE5E370B7848403A62CE92071E0240A335D8B30B7848407A9A40280C1E02406131FDAC11784840AA25A24A171E0240B4C59F271C7848408DAD6CE4301C0240D699C10B1D78484018605B10231C0240C25BEBA414784840
> 3169609;0106000020E61000000100000001030000000100000007000000F88016EA4B1B02404900712EBB7748402DE3C367571B024062167B7ABC77484090970D22191A024029718493C07748400C0C49DB131A0240034D85C5BF7748402595376E121A0240F8CDAE8DBF7748405DEF68218C1A0240CFD96AD9BD774840F88016EA4B1B02404900712EBB774840
> 3169610;0106000020E6100000010000000103000000010000000F00000012876A765F1F0240B70762C4AE774840B46815BFC61F024031DEC6FFAD774840021E8E1BD21F024095FD40C0AE7748402DE3C367571B024062167B7ABC774840F88016EA4B1B02404900712EBB774840AFAEC39D861B024001B3165EBA774840E9376E605C1C0240391FDF64B7774840DB2761B5D11C0240ED7023C1B57748405D7CA2D3061D0240AF330EFFB477484021A0A882591D0240D36BE8D2B37748404BF376C46C1D0240C0C1F28CB37748406AF6399CEB1D0240F18D752FB2774840ECB9450BFD1E0240A98DD792AF77484018F5C35C4F1F0240E6DBDEB2AE77484012876A765F1F0240B70762C4AE774840
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
> 3169618;0106000020E61000000100000001030000000100000007000000FC3199282F220240AA346C67017848409CE12FE22522024084357AB3F6774840E9DA8D3CDA220240329B697AF6774840F2601B49F32202408B455C72F67748400C3AA3C3FF2202409E39D8CAFE7748404FFAEC4FC52202401E41C32501784840FC3199282F220240AA346C6701784840
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
> 3169620;0106000020E6100000010000000103000000010000002C000000E78924E6CD1B0240054F8596117848404DCBE234D01C02404F5D35AA07784840268C18C00B1E0240FFDB124AFB7748403F19E7408A1E02403846F84EF67748400D22AD62B61E024024286E4BF4774840CB867CD9061F02406529F035F0774840F1ADB1127D1F02409878BB35EA774840762013C3A120024023E36159DB774840E10D13D95F210240BD34539AD1774840A57DFA117B210240BD2C4E65D077484077A07243C0210240410FFEB2CD7748404C45A6E6C8210240771C3FA8CE7748406D212C66D32102409DFC459ECF7748403E0FFFF8DF210240C91B5294D07748404C7CABC3ED210240C7990779D1774840CCD1B6EAFC2102408AA4AE51D2774840DA8133DA05220240DCF9ADC3D27748402DEDE8A615220240FB57647AD3774840DED7A83C2322024068671506D4774840F9AFDED12D220240B2860269D4774840299FB967392202408A1D28C5D47748402BDEF89E0A220240C5F4AEEAD377484062514E12E8210240A8C88531D37748409A19C0EAAA210240533E22DBD4774840EC5F70067120024068BF05B7E4774840255D7369632002404730E665E57748408B5933304920024063F419B9E677484062C3AE136C1F02400F28B3E5F17748406A1CDE48521F02401C7B801EF3774840AA8AE01C311F02405AD4C0B1F4774840640AD21CEA1E0240A106FF09F8774840CBFEC965BA1E02400105CC40FA774840A6A267A5951E0240098553DFFB774840DE0BD364701E02400329D57AFD774840C86967B64A1E024072E3CE11FF7748403BF31123181E02408A96AA2C01784840AC8F4094B61D02405FFB74BC04784840727AD536B11D0240158CBC9F04784840A75D4259181D0240F5A24F9D0A78484018605B10231C0240C25BEBA4147848402F6D1DD98D1B0240E35B18851A7848407305800A551B02403ACB16C41C78484014259E6F5E1B02407045D0EE15784840E78924E6CD1B0240054F859611784840
> 3169623;0106000020E6100000010000000103000000010000000600000079D22A6BED420240F52B967971784840DC713907C742024028F53D61877848403A182FBE11400240F8B6CD0F8178484099D362B3DB4002407A8A37357A784840ABB1C28F9B41024012BC978E7378484079D22A6BED420240F52B967971784840
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
> 3169625;0106000020E6100000010000000103000000010000007400000048EA2995E71C0240BC45220CCC774840BD2F53610E1D0240A3D4EFA5CB77484041628450321D024073BEBE45CB7748407187E649661D02407194E07FCA77484061F27345FD1D0240DDD7913FC87748402DB2890E5C1E0240C8C61ECBC6774840414520F6F11E0240D74C09B5C477484012231759FF1E0240D4EFA988C4774840567BDA671C1F0240AE940B6DC4774840FFD89F6C491F02401CA9333AC4774840B5ABF52C801F024093C33508C4774840524A3D8DD11F0240EE1BCDB6C3774840BD3FE721FB1F024098A1D9A2C3774840C25DFFC54320024034381F80C377484028710D057B200240BADEC28FC37748407846C86CBB200240170894AEC3774840C6F13E86CA200240F49A84B5C37748407D615F9CD220024040D05EB9C37748402F455DA50E210240CA91310CC47748405FEB770822210240CBC59358C477484091345D7B3221024067C2B3D3C47748400F6962903E2102409DDB1D5DC5774840580C1B484821024097DE3006C6774840EABE878F4E210240785C36D7C67748404243377A50210240CF3EBC84C777484046909F864D210240E30B5547C8774840059015C744210240DFFE1D09C9774840A1DEE1C23E2102405564E140C9774840B241FA2B38210240AB44AC7EC9774840DB23EC0231210240ECDE5AAAC97748402191B70D252102407CD868F3C9774840B484063302210240781FB60CCA7748401E1F656CBD20024088D0AC25CA7748403754D9F17E2002406219FB43CA77484020E313B2492002409A9D457BCA774840B479497DE41F02409F1B6513CB774840B4833C3BAE1F024039739E97CB774840ECC92455581F024086DE9B80CC7748409E9D6C51301F024052AAD5ECCC774840D7CA3182251F0240954F2E10CD774840A461D0471F1F024014893D25CD77484000567395A51E024093D4D7B6CE774840E2F589A9881E024071EE241DCF77484000488189501E024095B63CE5CF77484007B85639441E02409F95DD10D077484089F092A0F91D0240A15E032ED1774840D01D8500E31D0240D8BDB5A2D1774840A63EA527C91D0240CA46F827D277484092F8662AB01D0240EE684AB6D2774840C133AA61931D0240F3E5B159D3774840BAAC74236B1D0240A2C30359D477484035BEA4DB351D0240F9D57EE1D5774840E75B3353291D024013783044D6774840E047519D0F1D0240E5B8180ED777484067B3497AF71C0240495751E0D777484048AEC16DE51C0240DFA3CB7DD8774840AA1ADDBCBA1C0240D628C01ADA774840C2577C6A951C0240FB7864A3DB7748409D7C5C87731C024074885931DD7748406BB0186F551C02402B4EA0C4DE774840B08C0779351C0240D09EFC94E0774840DB5F0BBF1C1C02407CC0C11DE2774840ACB8CD680E1C02406CF1171EE37748401B2AFD71041C02402A6C05D0E3774840DF42D155E81B024037E9FE2EE6774840C85B2EF7D31B024064BBD713E8774840CE8EE084C01B0240E0F0A445EA77484049F2D2F3B31B024030312B10EC774840695EBC11AF1B0240F541A8C3EC774840BCC2ED5AA31B0240CD3254D1EE774840E26FE622991B0240B4E13D31F17748405C71FF5A911B0240DD02E25DF3774840DFC1B70C901B0240FA0A371BF47748405D24D781881B0240DB04174BF87748402E75367A861B0240271D2F62F97748402E906F7C731B02404D603B810378484016053FB0721B02409CA6DEF0037848409CCEF053751B024031F5ED4C04784840E13301E1911B0240B5913D7B04784840C2579F7EBC1B02407971121906784840A122466DB51B0240A1B3E06008784840933BABFFAD1B0240D63BD6C30A784840963C5D349E1B02409B42B5D90F784840E78924E6CD1B0240054F85961178484014259E6F5E1B02407045D0EE157848407305800A551B02403ACB16C41C784840BE701275541B0240BBEC063C1D784840F7C8CB31171B0240FD4C2A3F1D7848400A90F8CA171B0240D7C7512A1C784840A97265411A1B024059C2D4EF17784840E7A580721B1B02405CCF30FA1578484065D7F5B2291B0240103D7B911578484054B15046341B02406FFC513F0A784840DE315E362E1B0240A13EC25D067848402D1BA741FD1A0240D350448AEB774840198DC135F71A024022162E01EA7748408F5CC19E051B024055E500F1E8774840CEDD932F171B024032E53199E77748404FAF20B9471B0240D08EC6F0E3774840CAC5B27D691B02401AC39D67E177484017A26475871B02400CF21D2CDF7748404E45958D8D1B024013E737B1DE7748402AF45C419D1B0240030C8C74DD7748408D4EAF33B61B0240E1C872B2DB77484028CFE0EEBA1B024073FF405DDB774840FC26387FCD1B024026492C2BDA77484011B35C8DDD1B02407947CD21D9774840CE16DB41071C02404F435ADAD677484005C2A912281C024041584337D57748404BC7971A321C0240E6C41FB7D47748409321D948571C0240A1D0D917D3774840D56BFA61601C0240F5DD1AB2D2774840BC2F8644831C0240552A284FD1774840CAC58D37A31C0240B60744FBCF77484070C22A11901C0240DB1AF9BBCE77484048EA2995E71C0240BC45220CCC774840
> 3169626;0106000020E6100000010000000103000000010000000B000000C889D1FFAD1A024094F43003CF774840E19FC1EA9E1A02407C096D43CE774840EA9D7CDDC71A024083FB89B7CD774840459C5235431B0240CB17442BCC774840C1707BE2371C0240A2D6044CC9774840EC562733741C0240425C7DE9CC774840BD6F9E13F41B02403DCBD0D8CD774840E75028C0741B0240E14C845BCE774840F441F2642D1B0240CCD2299DCE774840E8AD3233EF1A0240AF7CCCCCCE774840C889D1FFAD1A024094F43003CF774840
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
> 3169629;0106000020E61000000100000001030000000100000004000000EC562733741C0240425C7DE9CC77484048EA2995E71C0240BC45220CCC77484070C22A11901C0240DB1AF9BBCE774840EC562733741C0240425C7DE9CC774840
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
> 3169632;0106000020E610000001000000010300000001000000060000009E8F3849134202406458B715507848400297CAD97E4202408120455C4C7848403DDE831E22430240E984965947784840F6FD77102F43024081E97EF24B7848403426ECA52A430240CCC7F7D14E7848409E8F3849134202406458B71550784840
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
> 3169634;0106000020E61000000100000001030000000100000007000000E9AB7C4E4C3C0240A8C0378E207848400A386B09D33C0240B630345922784840AA9076493A3D0240B88A649B237848401DB9CD129D3B02408D8C57A03178484086AE5CF0903A0240BE159064247848409E4F9BC07E3B0240CB85901021784840E9AB7C4E4C3C0240A8C0378E20784840
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
> 3169636;0106000020E610000001000000010300000001000000090000007338030EDA3802406AC13FC84E784840FEF324E466380240A11C50D852784840354E2F79D8360240C2FB83B460784840F0A87296DD350240D8F4136F69784840CA9BE8046A3502400B925C6E687848404408705DA7360240DBE7F6925D7848400EF2FA7D9F380240C2BC60FD4B784840BD508C23A3380240DC71EA294C7848407338030EDA3802406AC13FC84E784840
> 3169637;0106000020E610000001000000010300000001000000080000005C70B1CBDB3C024066819DAA797848406B80879C794102400D6255CA507848409E8F3849134202406458B71550784840C1F338CBC34102403557AED55278484033068BD8A04102403C77B30A547848407DF09859463D02408B0F14967A7848402CF93327293D02407F05F8547A7848405C70B1CBDB3C024066819DAA79784840
> 3169638;0106000020E610000001000000010300000001000000070000009E8F3849134202406458B715507848403426ECA52A430240CCC7F7D14E784840614621AD2643024002956ED75078484086459F352343024088350FA25278484033068BD8A04102403C77B30A54784840C1F338CBC34102403557AED5527848409E8F3849134202406458B71550784840
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
> 3169650;0106000020E6100000010000000103000000010000000C00000058B752BE1C2702402CD54F9AEA77484029FB6A270D28024004D01D68E6774840E789809512280240A2C71CAAF07748405BBA48A61D2802408FB1840BFF774840CF8B8573712702409880B069FF774840D6F8F5872D2702403DAB408DFF774840BE42327E29270240251F5B6AFA7748407A34080421270240037D64D9EE77484074C100E020270240B7CC7ABDEE7748403F77AFAF1F27024056485678ED774840F012018C1F2702408521954CED77484058B752BE1C2702402CD54F9AEA774840
> 3169651;0106000020E6100000010000000103000000010000000F00000026E015DE0B330240AD35694E5E7848407381B9954233024020ABA7765C784840DDDACF7462330240EA3AC8595B7848408BEC56D4D233024055A7736F5778484013522B709B340240395452725078484085A16C1CBA3402408001A501527848401019630ABB34024048D0F70C52784840E01DDCF8BD3402405205F531527848404C1CB481F433024082932B13597848400C20E22183330240B06C2DF25C784840F9F10D185A3302400929A7595E7848409FFF0A664633024009BC36035F784840C784DAB23033024055FD4CB45F7848400D122EFA2A330240BCAA2E7D5F78484026E015DE0B330240AD35694E5E784840
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
> 3169663;0106000020E610000001000000010300000001000000040000009960BA4A7F2802404B26FEA511784840465752E57D280240962F140710784840E9CACDBFB1280240D22E548E117848409960BA4A7F2802404B26FEA511784840
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
> 3169668;0106000020E6100000010000000103000000010000000C000000804649A1741E02400E4C580703784840D5D26BBB421E02403D6F8AA100784840D3C869035A1E02402F5A22B1FF77484019CE82D67F1E02408BB8A618FE774840FB6C1B4EA51E0240AA3EE27AFC774840E8BA8A45CA1E02408FAC95D8FA77484044BCE845FA1E02401804869FF87748407D35FB45411F0240BD9F8646F57748407E1819CC601F0240B94861C8F3774840FD3B5639B01F02408FB3C866F7774840D5E7DB58BB1F024037890B7902784840804649A1741E02400E4C580703784840
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
> 3169670;0106000020E610000001000000010300000001000000080000007E1819CC601F0240B94861C8F3774840D267D1737C1F024021F87477F27748405C9AA9D95920024089E69848E77748408B104327E5200240CDF629F7EB774840E5E48889F4200240C6F89DF001784840D5E7DB58BB1F024037890B7902784840FD3B5639B01F02408FB3C866F77748407E1819CC601F0240B94861C8F3774840
> 3169671;0106000020E610000001000000010300000001000000070000005C9AA9D95920024089E69848E7774840D267D1737C1F024021F87477F27748407E1819CC601F0240B94861C8F37748406A1CDE48521F02401C7B801EF377484062C3AE136C1F02400F28B3E5F17748408B5933304920024063F419B9E67748405C9AA9D95920024089E69848E7774840
> 3169672;0106000020E6100000010000000103000000010000000B0000008B104327E5200240CDF629F7EB7748405C9AA9D95920024089E69848E7774840DF51E91274200240CB1A65F5E577484042D8EF8178200240534F281BE67748403466497F28210240973253F6EB774840AF499BCB702102402B3E9F61EE7748404D1771B51E220240B89BDA0EEE7748409CE12FE22522024084357AB3F6774840FC3199282F220240AA346C6701784840E5E48889F4200240C6F89DF0017848408B104327E5200240CDF629F7EB774840
> 3169673;0106000020E61000000100000001030000000100000006000000255D7369632002404730E665E5774840EC5F70067120024068BF05B7E4774840DF51E91274200240CB1A65F5E57748405C9AA9D95920024089E69848E77748408B5933304920024063F419B9E6774840255D7369632002404730E665E5774840
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
> 3169675;0106000020E6100000010000000103000000010000000A0000003466497F28210240973253F6EB774840CACBC0A7E7220240C7F9A367EB7748404D882BFEEF2202403109AF4FF377484030518BF1D622024083F3815BF377484050C237A0D8220240674F95EAF4774840E9DA8D3CDA220240329B697AF67748409CE12FE22522024084357AB3F67748404D1771B51E220240B89BDA0EEE774840AF499BCB702102402B3E9F61EE7748403466497F28210240973253F6EB774840
> 3169676;0106000020E61000000100000001030000000100000005000000E9DA8D3CDA220240329B697AF677484050C237A0D8220240674F95EAF4774840ACFE829AF1220240565483DFF4774840F2601B49F32202408B455C72F6774840E9DA8D3CDA220240329B697AF6774840
> 3169677;0106000020E61000000100000001030000000100000005000000ACFE829AF1220240565483DFF477484050C237A0D8220240674F95EAF477484030518BF1D622024083F3815BF37748404D882BFEEF2202403109AF4FF3774840ACFE829AF1220240565483DFF4774840
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
> 3169706;0106000020E61000000100000001030000000100000004000000FAFF2C76FE460240A0F2FBDB95784840840DD44828470240235DF372947848402788CDC862470240B0B6064097784840FAFF2C76FE460240A0F2FBDB95784840
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
> 3169720;0106000020E6100000010000000103000000010000000B0000003426ECA52A430240CCC7F7D14E78484017AD83A759450240A320EB764C784840F8BDC2523746024084DE38904B784840D7EB77C6C6460240BC4F5686527848406C70973F86460240B5287EF9547848406DD075617D460240CBD60F8F547848401BCC49D20E460240A7AAC5574F784840DD194B28574502400B96DF285078484086459F352343024088350FA252784840FC1B17AD2643024018EFB1D9507848403426ECA52A430240CCC7F7D14E784840
> 3169721;0106000020E61000000100000001030000000100000008000000BBB4B8FA76450240B6A2F0385E784840AB496D378B450240D4DF193E5F784840DA084553AC450240A3ADD3EA60784840DB8CF268F843024083B480E36F784840900A5F84E74302403A5A49FF6F7848407FB090EECA430240F46A5E7F6D7848406FA39A5BC5430240BA1F1A026D784840BBB4B8FA76450240B6A2F0385E784840
> 3169722;0106000020E61000000100000001030000000100000009000000E1962C27B7470240443EDD3E9878484056539405454C0240940DCD0270784840D95D7D19A14D024011A7F58D80784840269B8059774D0240089FD10082784840272FB3A45E4D0240900F2BDC82784840E403D4FF3C4C02400A7769D9747848405CAC7DF919480240AC4E818B9978484058543D86E6470240087F61DE98784840E1962C27B7470240443EDD3E98784840
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
> 3169799;0106000020E6100000010000000103000000010000000F0000002FBC55A9784E02407B51D8E8AE7848406DA450F5E94B02405E06F49AC57848401A8699DD8D4B024057FB8774C8784840FD97A992F74A02403CC437D3CB784840F034F045554A0240A2636612CE7848403ED074FAAB490240A9B6401FCF784840EB7014046A480240745015E4CF78484097581D7E37470240C5C9C2F8C078484047608735FF460240F9E78A3BBE7848409D432E0E494A024003450E2CA1784840CB9AB6347B4B024080755AA296784840C38AC668E54B02406B4EBFCC9B784840F762E680694C02406F48A02FA2784840C7F74CDC114D0240DA7BB43AAA7848402FBC55A9784E02407B51D8E8AE784840
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
> 3169802;0106000020E61000000100000001030000000100000007000000E1962C27B7470240443EDD3E98784840EB801B2BE7470240DF0CA6E0987848405CAC7DF919480240AC4E818B997848404AF1AF90CE47024078ADAC0D9C78484064A29F75B2470240F52576B29A7848400A9B69FE934702409F91CF3999784840E1962C27B7470240443EDD3E98784840
> 3169803;0106000020E6100000010000000103000000010000000400000051A7D6C23E4602402679263593784840ACB0010A0D4302404F0E166CAF784840873D0AA6FA430240C69EEF828B78484051A7D6C23E4602402679263593784840
> 3169804;0106000020E6100000010000000103000000010000000D00000056D490373344024059A55118AF78484022970BE8854302409B6536CCB4784840DB8D2D5FBC420240140AFFC1BB784840A33438EDC742024058F6F4FBB9784840469F2A81E74202401E7D4D29B5784840ACB0010A0D4302404F0E166CAF78484051A7D6C23E4602402679263593784840FAFF2C76FE460240A0F2FBDB957848405945451B324502405BE9A519A67848406609029F1C45024023131DDCA6784840BE47A8D4FF4402406D6B27E0A77848402CA6F1D1E04402400280CAF7A878484056D490373344024059A55118AF784840
> 3169871;0106000020E6100000010000000103000000010000000B000000480B76486A510240E07B6280A978484025F0D9B7D54E02403CCA1287C07848408C3F5BF4744B0240DBA97EA8DE78484080F4D5A6B44602409846B9A5087948404474FAEF7E46024014BBF66C0A794840A3C052E465460240ECEB2A030A794840975FC6AF7E4502401A8B8C3006794840D6602B566F4A02406DE79992DA784840DD5BDA32A44D024049C0DA3DBE78484076E94B11C9500240F84DE822A2784840480B76486A510240E07B6280A9784840
> 3169872;0106000020E61000000100000001030000000100000006000000224154B60C530240776B86EB9A784840480B76486A510240E07B6280A978484076E94B11C9500240F84DE822A2784840607FAC4F2751024011FF81BE9E784840C2E9C5CFA952024011C376F699784840224154B60C530240776B86EB9A784840
> 3169873;0106000020E6100000010000000103000000010000000A000000224154B60C530240776B86EB9A784840A8E7E426465402403BE47E1590784840F63D0A5F805402405A1E02E192784840F09E42CF875402405D90553C9378484050EBC7A22D52024092CDE1C9A7784840A68E910E28520240164CF888A77848404F0BC3C6F651024038654F48A5784840B6BDAB2774510240243B38DAA9784840480B76486A510240E07B6280A9784840224154B60C530240776B86EB9A784840
> 3169874;0106000020E610000001000000010300000001000000080000006DA450F5E94B02405E06F49AC57848400B110A4263490240E12C1806DC784840EB7014046A480240745015E4CF7848403ED074FAAB490240A9B6401FCF784840F034F045554A0240A2636612CE784840FD97A992F74A02403CC437D3CB7848401A8699DD8D4B024057FB8774C87848406DA450F5E94B02405E06F49AC5784840
> 3169875;0106000020E61000000100000001030000000100000009000000D18D1A89B0440240B6F344E1B778484005B8571B46420240DF2BF738CD7848403DEDF74F5342024046EBD535CB784840DCE0127865420240BE6D347FC8784840891DC2EE6C42024072935B61C7784840F36E76ADEF4302403E3303DDB97848409AB262F879440240C91E6332B57848408CD89401984402407FC28CACB6784840D18D1A89B0440240B6F344E1B7784840
> 3169876;0106000020E6100000010000000103000000010000000B000000D18D1A89B0440240B6F344E1B77848408CD89401984402407FC28CACB67848409AB262F879440240C91E6332B5784840B598B14E8D440240F2FEC382B47848401953D17895440240C433E638B4784840087BDB0C98440240FF858821B47848403FE2EAA7B4440240CF6AD388B578484039B1B7DFB7440240444BD9B3B57848409CE9CE2ECB4402407DF563A5B6784840E13E949DCE4402403B3E6AD0B6784840D18D1A89B0440240B6F344E1B7784840
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
> 3169878;0106000020E610000001000000010300000001000000090000000A9B69FE934702409F91CF399978484064A29F75B2470240F52576B29A7848404AF1AF90CE47024078ADAC0D9C7848402CA2E4455E470240E34E3FDC9F7848401B3CCDB25B470240618C8BBC9F784840C14DABB32447024065170E259D7848407C2D5CFE264702406F1CF30F9D784840892C8E2075470240D314F24F9A7848400A9B69FE934702409F91CF3999784840
> 3169879;0106000020E61000000100000001030000000100000005000000F36E76ADEF4302403E3303DDB9784840891DC2EE6C42024072935B61C7784840DB8D2D5FBC420240140AFFC1BB78484022970BE8854302409B6536CCB4784840F36E76ADEF4302403E3303DDB9784840
> 3169880;0106000020E6100000010000000103000000010000000A0000009AB262F879440240C91E6332B5784840F36E76ADEF4302403E3303DDB978484022970BE8854302409B6536CCB478484056D490373344024059A55118AF784840261CD4847D4402400ABD9FCEB2784840B03FF1F995440240896C1D07B4784840087BDB0C98440240FF858821B47848401953D17895440240C433E638B4784840B598B14E8D440240F2FEC382B47848409AB262F879440240C91E6332B5784840
> 3169894;0106000020E610000001000000010300000001000000060000001529EC9795410240FF9537D9F978484063E14783224102400239AFE7F87848405A1C805E30410240E27DD390F678484045E85B22434102407CA280E9F57848400D21613544410240F15A75E0F57848401529EC9795410240FF9537D9F9784840
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
> 3169896;0106000020E610000001000000010300000001000000090000000B110A4263490240E12C1806DC7848403D0C59487C460240C6141CC7F57848405107843E544402405E8353A5DA7848403F65BEDF84440240FDF170F5D87848405EFD693B85440240412A6DF2D878484094751F0E344502405A7D7BDFD278484097581D7E37470240C5C9C2F8C0784840EB7014046A480240745015E4CF7848400B110A4263490240E12C1806DC784840
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
> 3169899;0106000020E610000001000000010300000001000000090000000D21613544410240F15A75E0F578484045E85B22434102407CA280E9F57848405A1C805E30410240E27DD390F6784840E5D4789B44410240B9CD9095F37848404ED0AB0945410240146D3C87F37848403CEF84F955410240D16CAA07F1784840FB23CF62824102409F453430F37848404DD457B33D41024061E4B08FF57848400D21613544410240F15A75E0F5784840
> 3169903;0106000020E6100000010000000103000000010000000B0000008368D821EA44024016F247B703794840B61E1EE4A24302408CE6341C0F7948404D234A18654302403F807B74107948401529EC9795410240FF9537D9F978484000B3E15818420240E1C295F0FA78484099CBE5272442024087DD9109FB78484052C6AA6198420240BE9EA502FC784840BF570F4892430240C5A499EBFE7848406783D41A8E4402401677AB6A027948402B02BE79E244024020170896037948408368D821EA44024016F247B703794840
> And here is my technical environment:
> SELECT postgis_full_version(), version()
> postgis_full_version :
> POSTGIS="1.3.5" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel. 4.6.0, 21 Dec 2007"
> USE_STATS
> version:
> PostgreSQL 8.3.6 on x86_64-pc-linux-gnu, compiled by GCC cc (GCC) 4.2.4
> (Ubuntu 4.2.4-1ubuntu3)
New description:
When trying to merge several geom using ST_Union() function, I sometimes
get an exception / internal error:
SQLSTATE[XX000]: Internal error: 7 ERROR: GEOS union() threw an error!
Here is the SQL query (which perfectly works on thousands of other
ST_Union() I did using the very same method) :
SELECT
ST_SetSRID(ST_Multi(ST_Union(place_geom)), 4326) AS place_geom
FROM
geo_place
WHERE
place_id IN
(3169600,3169596,3169647,3169665,3169562,3169564,3169595,3169597,3169598,3169618,3169619,3169648,3169674,3169675,3169676,3169677,3169649,3169599,3169604,3169605,3169633,3169634,3169635,3169650,3169658,3169678,3169563,3169567,3169569,3169575,3169565,3169561,3169615,3169616,3169617,3169672,3169607,3169620,3169668,3169669,3169670,3169673,3169566,3169585,3169588,3169601,3169602,3169603,3169606,3169659,3169664,3169651,3169591,3169632,3169637,3169638,3169703,3169636,3169662,3169663,3169568,3169570,3169574,3169559,3169560,3169518,3169594,3169625,3169671,3169630,3169586,3169587,3169584,3169589,3169581,3169709,3169720,3169705,3169504,3169505,3169507,3169508,3169509,3169510,3169517,3169519,3169520,3169521,3169522,3169542,3169544,3169549,3169554,3169556,3169557,3169609,3169627,3169657,3169624,3169628,3169629,3169583,3169710,3169707,3169721,3169506,3169626,3169536,3169537,3169538,3169539,3169543,3169545,3169546,3169547,3169548,3169550,3169551,3169553,3169555,3169558,3169511,3169512,3169513,3169514,3169515,3169516,3169540,3169541,3169610,3169656,3169704,3169706,3169708,3169801,3169803,3169804,3169579,3169623,3169531,3169532,3169533,3169552,3169525,3169530,3169593,3169654,3169655,3169700,3169722,3169802,3169701,3169876,3169877,3169878,3169880,3169577,3169879,3169576,3169534,3169526,3169527,3169503,3169523,3169535,3169798,3169799,3169702,3169872,3169875,3169578,3169582,3169498,3169499,3169500,3169501,3169502,3169524,3169528,3169529,3169571,3169572,3169871,3169874,3169895,3169896,3169903,3169897,3169873,3169573,3169580,3169590,3169894,3169898,3169899)
Attached '''hex-polygons-ticket-238.txt''' file is the dataset of polygons
I am trying to merge which generates this internal error.
USE_STATS
version:
Ticket URL: <http://trac.osgeo.org/geos/ticket/238#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
