[geos-devel] Bug in GEOSEquals predicate ?
Sean Gillies
sgillies at frii.com
Mon Mar 16 11:52:07 EDT 2009
The GEOS C API returns a integer value of 2 to indicate an error. It's
good to learn that geometry collection predicates aren't supported.
On Mar 16, 2009, at 9:46 AM, Martin Davis wrote:
> GEOS does not support evaluating predicates on GEOMETRYCOLLECTIONS
> (due to the potential complexity and lack of obvious semantics of
> heterogeneous collections).
> In JTS trying to do this throws an exception. I'm not sure how GEOS
> reacts - or possibly shapely is not handling this gracefully?
> Pascal Leroux wrote:
>> Hi all
>> while searching for intersections between polygons (buildings), I
>> have found shapes that make "equals" predicate crash. With simpler
>> shapes, it occurs too :
>> >>> from shapely.geometry import Polygon
>> >>> p1 = Polygon(((0,0),(0,10),(10,10),(10,0),(8,0),(8,8),(2,8),
>> (2,0)))
>> >>> p2 = Polygon(((2,0),(2,8),(8,8),(7,4),(8,0)))
>> >>> inter = p1.intersection(p2)
>> >>> inter.is_valid and p1.is_valid and p2.is_valid
>> True
>> >>> inter.wkt
>> 'GEOMETRYCOLLECTION (POINT (8.0000000000000000 0.0000000000000000),
>> LINESTRING (8.0000000000000000 8.0000000000000000,
>> 2.0000000000000000 8.0000000000000000), LINESTRING
>> (2.0000000000000000 8.0000000000000000, 2.0000000000000000
>> 0.0000000000000000))'
>> >>> inter.equals(p1)
>> False
>> >>> inter.equals(p2)
>> Traceback (most recent call last):
>> File "<stdin>", line 1, in <module>
>> File "/usr/lib/python2.5/site-packages/Shapely-1.0.11-py2.5.egg/
>> shapely/predicates.py", line 34, in __call__
>> return bool(self.fn(self.context._geom, other._geom))
>> shapely/predicates.py", line 21, in errcheck
>> raise PredicateError, "Failed to evaluate %s" % repr(self.fn)
>> shapely.geos.PredicateError: Failed to evaluate <_FuncPtr object at
>> 0x96a3bf4>
>> I have got a Bus Error on MacOSX (libgeos version 3.0.0) and a
>> Segmentation Fault on Ubuntu (libgeos version 3.0.3) with an
>> equivalent code written in C (so I think Shapely is not involved).
>> Any idea ? Did I miss something ?
>> Pascal
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
