[geos-devel] Re: [GEOS] #232: Static string in WKBReader causes glibc errors when Geos is statically linked
GEOS geos-trac at osgeo.org
Tue Mar 17 12:37:41 EDT 2009
linked
 Reporter:  yvesdaemen  |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:  3.0.4
Component:  Default     |      Version:  3.0.3
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment (by pramsey):
 Can you attach a test program? Otherwise it is unlikely anyone will take
 the time to first create an example program before working up a general
 solution. Even better, attach a general purpose patch.
Ticket URL: <http://trac.osgeo.org/geos/ticket/232#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
