[geos-devel] [GEOS] #241: GEOSBuffer produces an invalid geometry
GEOS geos-trac at osgeo.org
Thu Mar 19 12:49:49 EDT 2009
 Reporter:  pleroux     |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.1.1
Component:  Default     |     Version:  3.0.0
 Severity:  Unassigned  |    Keywords:
 Here's a a valid polygon for which the GEOSBuffer function produces an
 invalid geometry.
 At the beginning, I didn't test the returned geometry but only wrote it in
 WKT format (and it "worked"). I tested different values for dist (1 (m)
 and 2) and, with 1, it is obvious than the result is not valid (a big hole
 of the poygon disappears and two small polygons are created). With 2, it
 "seems" good and the obvious error obtained with 1 don't occur any more.
 Even if they are not valid, I think they're interesting to investigate
 >>> from shapely.wkb import loads
 >>> polygon =
 loads(open('polygon.hexwkb').readline().rstrip().decode('hex'))
 >>> polygon.is_valid
 True
 >>> buffer_1 = polygon.buffer(1.)
 >>> buffer_1.is_valid
 False
 >>> buffer_2 = polygon.buffer(2.)
 >>> buffer_2.is_valid
 False
 >>> print >> open('buffer_1.hexwkb','w'), buffer_1.wkb.encode('hex')
 >>> print >> open('buffer_2.hexwkb','w'), buffer_2.wkb.encode('hex')
 On MacOSX, libgeos 3.0.0, with an equivalent code in C, the problem occurs
 too.
Ticket URL: <http://trac.osgeo.org/geos/ticket/241>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
