[geos-devel] GEOS 3.1.0
William Kyngesburye woklist at kyngchaos.com
Sun Mar 22 12:28:16 EDT 2009
On Mar 22, 2009, at 11:19 AM, William Kyngesburye wrote:
> This was not a problem when I built 3.1 from SVN in November, r2230.
Duh, probably because I had to run autogen, thus getting a local
working libtool.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
