[geos-devel] [GEOS] #243: a question about the conversion from Geometry* to Polygon*
GEOS geos-trac at osgeo.org
Wed Mar 25 05:10:24 EDT 2009
 Reporter:  aya          |       Owner:  geos-devel at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  3.1.1
Component:  Default      |     Version:  3.1.0rc2
 Severity:  Unassigned   |    Keywords:  conversion, Geometry*, Polygon*
 I use the following function to get the intersection of two polygons which
 have holes and the value returned is Geometry *.
 geos::precision::EnhancedPrecisionOp:: intersection(Poly_A,Poly_B);
 If getGeometryTypeId() tells me the geometry returned is a polygon, how
 can I get a pointer Polygon * from Geometry * safely ? If I convert it
 directly, is it always safe ?
 Thanks.
Ticket URL: <http://trac.osgeo.org/geos/ticket/243>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
