[geos-devel] Re: [GEOS] #244: Buffer fails to buffer elements
of multpolygon
Martin Davis
mbdavis at refractions.net
Fri May 8 17:09:11 EDT 2009
Works fine in JTS.
Input: [[ MULTIPOLYGON - 52 elements, 3038 pts ]]
Output: [[ MULTIPOLYGON - 52 elements, 3038 pts ]]
GEOS wrote:
> #244: Buffer fails to buffer elements of multpolygon
> Reporter: pramsey | Owner: geos-devel at lists.osgeo.org
> Type: defect | Status: new
> Priority: major | Milestone: 3.1.1
> Component: Default | Version: 3.0.3
> Severity: Unassigned | Resolution:
> Keywords: |
> Comment (by strk):
> I attach an XML tester, Martin any tip from your side ? How does JTS deal
> with that ?
> geos-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
