[geos-devel] Re: [GEOS] #244: Buffer fails to buffer elements of multpolygon
GEOS geos-trac at osgeo.org
Tue May 12 09:59:58 EDT 2009
 Reporter:  pramsey     |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:  3.1.1
Component:  Default     |      Version:  3.0.3
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment (by strk):
 bug244-simp2.xml yet another simplification. This time it's 4 polygons
 input.
 Note that dropping any more polygon from input results in a correct
 output.
 Keeping all of 4 polygons results in a single polygon output
 orig     |
          : MultiPolygon[BS] with 3 elements
          :   Polygon[] with 1 rings
          :    ring 0 has 204 points
          :    ring 0 has 404 points
          :    ring 0 has 25 points
 buffered |
          : Polygon[BS] with 1 rings
Ticket URL: <http://trac.osgeo.org/geos/ticket/244#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
