[geos-devel] GEOS cross-heap problems
Wed May 13 11:29:38 EDT 2009
Sean Gillies wrote:
> On May 13, 2009, at 7:42 AM, Mateusz Loskot wrote:
>> Frank Warmerdam wrote:
>>> strk wrote:
>>>> On Wed, May 13, 2009 at 12:19:23AM -0400, Frank Warmerdam wrote:
>>>> Only, it'll have to stay (I've read Mateusz suggesting using
>>>> type-specific destroyers).
>>> I cannot imagine why a type specific destroyer would be needed
>>> for simple malloc()/free() buffer allocations.
>> Frank,
>> But GEOS user does not know what allocator is hidden behind
>> GEOSGeomToWKT function and he does *not* need or want to know.
>> GEOSFree exposes all the meat that is supposed be encapsulated
>> and it makes GEOS C API not symmetric so confusing.
> Aren't we supposed to be using the reader/writer API now? Add
> GEOSWK*Writer_Free functions (if we must) to those interfaces and
> GEOSFree to address the problem with deprecated GeomToWKT?
Sean / Mateusz,
It is my personal opinion that since these buffers are just allocated
from the heap with malloc(), exposing a GEOS specific free - and making
it clear when it is suitable to use is a more than adequate solution.
If you guys feel strongly enough about type specific, or reader/writer
interface specific deallocators for these buffers then I'd suggest you
bring it to a motion to replace/override my implementation and I'll
then adapt GDAL appropriately.
I'm in a bad mood, and less receptive than normal to esoteric conceptual
correctness wanking.
Regards,
