[geos-devel] Re: [GEOS] #241: GEOSBuffer produces an invalid
geometry
geos-trac at osgeo.org
Thu May 14 04:16:00 EDT 2009
#241: GEOSBuffer produces an invalid geometry
Reporter: pleroux | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 3.1.1
Component: Default | Version: 3.0.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by pleroux):
With r2509, the problem doesn't persist any more. "is_valid" attribute is
True for the two buffers (see example code above) and, visually, the big
hole that disappeared with older releases is correctly handled now.
Ticket URL: <http://trac.osgeo.org/geos/ticket/241#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
