[geos-devel] 3.0.
Obe, Regina robe.dnd at cityofboston.gov
Thu May 28 08:14:13 EDT 2009
Paul,
Under OpenSUSE 10.3 -- I have similar issue with trying to compile geos
3.0 branch but with different file.
To get to that point I did a fresh checkout
svn checkout http://svn.osgeo.org/geos/branches/3.0 geos30
cd geos30
sh autogen.sh
./configure
make & make install
The autogen looks fairly standard
sh autogen.sh
Running aclocal -I macros
Running autoheader
Running libtoolize
Running automake
configure.in:32: installing `./missing'
configure.in:32: installing `./install-sh'
capi/Makefile.am: installing `./depcomp'
swig/python/Makefile.am:15: installing `./py-compile'
Running autoconf
then make
everything before this point looks okay and then
I get this error
mv -f .deps/SimplePointInRing.Tpo .deps/SimplePointInRing.Plo
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -g -O2 -DGEOS_INLINE
-Wall -ansi -pedantic -Wno-long-long   -o libalgorithm.la
CGAlgorithms.lo CentroidArea.lo CentroidLine.lo CentroidPoint.lo
ConvexHull.lo HCoordinate.lo InteriorPointArea.lo InteriorPointLine.lo
InteriorPointPoint.lo LineIntersector.lo MCPointInRing.lo
MinimumDiameter.lo NotRepresentableException.lo PointLocator.lo
RobustDeterminant.lo SIRtreePointInRing.lo SimplePointInAreaLocator.lo
SimplePointInRing.lo
libtool: link: `CGAlgorithms.lo' is not a valid libtool object
make[2]: *** [libalgorithm.la] Error 1
make[2]: Leaving directory `/projects/geos30/source/algorithm'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/projects/geos30/source'
make: *** [all-recursive] Error 1
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
