[geos-devel] 3.2.0 Preparations
strk
strk at keybit.net
Fri May 29 04:06:56 EDT 2009
On Wed, May 27, 2009 at 12:27:14PM -0700, Paul Ramsey wrote:
> I have triaged most of the bugs in the tracker now, and I think we
> have a reasonable working set to examine and either fix or defer now
> under the 3.2 milestone. Once that list has been worked, we can move
> to an RC1 release.
> http://trac.osgeo.org/geos/report/3
Thank you.
I got my involvement in the process approved, so I'm with you.
I'd give end of June as a release date target, so Safe (who is
sponsoring my recent developments) has time to properly test the
new code. Ok with all ?
If I have enough time I'll also give another pass at packages
port syncs so we can call 3.2.0 a JTS-1.10 port w/out being
embarassed :)
--strk;
Free GIS & Flash consultant/developer () ASCII Ribbon Campaign
http://foo.keybit.net/~strk/services.html /\ Keep it simple!
