[geos-devel] tests\unit\capi\GEOSGeomFromWKBTest.cpp missing
Obe, Regina robe.dnd at cityofboston.gov
Sun May 31 21:28:26 EDT 2009
Was the tests\unit\capi\GEOSGeomFromWKBTest.cpp removed.  I'm trying to compile under visual studio 2008 with the msvc9 solution provided and this apparently has link to this and says it doesn't exist.
I don't see it in that folder so assume it should just be removed from the solution.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090531/09a04ce6/attachment.html
