[geos-devel] Which one of "n" polygons contains this point?
Frederik Ramm
frederik at remote.org
Fri Nov 6 16:15:48 EST 2009
I have a few hundred polygons representing country borders. And I
have a few hundred million points, and for each, I want to record the
country it lies in. I have about an hour of computing time to spend for
this task.
A simple and working algorithm is of course to create the polygons for
the countries, then for each point, do a "contains" test for all
polygons until a match is found. Unfortunately many of these polygons
are quite complex (the outline taking anything from 1.000 to 50.000
nodes) which makes the "contains" test expensive, especially if you are
planning to execute it for a large number of points.
Now I can think of a number of optimisations (divide earth into a grid
of rectangles, record which polygons overlap any given grid square, thus
reducing the number of "contains" tests you have to perform), but before
I set about playing around with these I wanted to ask if you are aware
of anything deep down it the GEOS guts that might help.
There is a class of algorithms that efficiently solves my problem,
called "point location algorithms", however the only available
implementation for this I could find comes from the CGAL library which
has a license problem (my application must be GPL and the specific CGAL
component I'm after is licensed in a GPL incompatible way).
Thank you
Frederik
Frederik Ramm ## eMail frederik at remote.org ## N49°00'09" E008°23'33"
