[geos-devel] 3.2.0rc1 tagged
Obe, Regina
robe.dnd at cityofboston.gov
Tue Nov 17 13:36:40 EST 2009
Yes that was it. I guess I should have read the glaring readme on geos site :)
Is it needed for solution compiles? I think I've always compiled with the full VS 2008 product before so maybe its already part of the solution.
Also just curious - what is the reason why autogen.bat is not packaged in the tar ball? Seems a bit of a pain to have to
go to svn for that file.
My VC tests have failed though the dll compiles -- trying again -- but on first blush --
This file is missing in the package
..\..\..\tests\unit\capi\GEOSGeomFromWKBTest.cpp
and the vc unit proj file references it. So that is the cause of the first trial test failure.
Thanks,
Regina
________________________________________
From: geos-devel-bounces at lists.osgeo.org [geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey [pramsey at cleverelephant.ca]
Sent: Friday, November 13, 2009 4:44 PM
To: GEOS Development List
Subject: Re: [geos-devel] 3.2.0rc1 tagged
Yes, VC users must remember to run autogen.bat before starting...
P
On Fri, Nov 13, 2009 at 1:29 PM, strk <strk at keybit.net> wrote:
> On Fri, Nov 13, 2009 at 04:13:14PM -0500, Obe, Regina wrote:
>> Now for VC++ 2009 express, I tried compiling and it seems I need inttypes.h? I don't recall that being a dependency before (GEOS 3.1) or maybe I always had it before on my prior boxes and didn't know it.
> Was in 3.1 too, and only in platform.h.
> Maybe you need to copy platform.h.vc to platform.h ?
> --strk;
> Free GIS & Flash consultant/developer () ASCII Ribbon Campaign
> http://foo.keybit.net/~strk/services.html /\ Keep it simple!
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
