[geos-devel] Benchmark between various geometry libraries
Martin Davis mbdavis at refractions.net
Wed Nov 18 11:55:32 EST 2009
I'm not sure that anything "went wrong" with the tests.  The results may
be due to fundamental design differences between GGL and GEOS.  These
include:
- GEOS uses a less efficient memory handling strategy, primarily due to
the goal of tracking JTS closely (and also due to the substantial
brainpower required to grok C++ template programming)
- GEOS focuses heavily on providing robustness and ability to handle a
wide variety of real-world geometry correctly.  This requires using some
algorithms and extra checking which have an impact on performance
The robustness question I think is a key one.  In order for a library to
be viable in an uncontrolled production setting such as PostGIS, it
needs to be highly robust.  I think this needs to be considered of equal
importance to performance for these kinds of uses.
Maxime van Noppen wrote:
> Hi list,
> A geometry library is currently being reviewed by the Boost project (GGL
> - Generic Geometry Library)[1] and they did some benchmarks available here:
> http://trac.osgeo.org/ggl/wiki/IntersectionMore
> http://trac.osgeo.org/ggl/wiki/IntersectionStarComb
> Depending on the situations geos performs well or quite bad.
> It could be interesting to investigate what went wrong with those tests.
> [1] http://lists.boost.org/boost-users/2009/11/53451.php
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
