[Fwd: Re: [geos-devel] Benchmark between various geometry libraries]
Martin Davis
mbdavis at refractions.net
Wed Nov 18 17:38:14 EST 2009
Hartmut Kaiser wrote:
> It's not that allocation is necessarily slow
Well, compared to the JVM it is. Java is amazingly fast at allocating
objects.
> Sharing is certainly a bit trickier this way, but allocating on the stack helps defining proper ownership of the data.
For better or worse, JTS/GEOS already has well-defined sharing
policies. Performance-wise, it's probably for worse (in C land) - many
of the intermediate data structures are designed to be usable on their
own - which means that their components are shared. And since they are
mostly dynamic in nature, I think this implies that their component
objects need to be heap allocated, correct?
Actually, I'm a bit puzzled by your code example. If I understand it,
you say that
vector<bla> v;
// use v
results on stack-only memory usage. But aren't vectors dynamically
sized? Doesn't the dynamically created memory get allocated from the
heap?
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
Martin Davis
(250) 383-3022
