[geos-devel] Benchmark between various geometry libraries
Maxime van Noppen
maxime at altribe.org
Thu Nov 19 11:16:53 EST 2009
strk wrote:
> I occasionally did rounds of such cleanups, but I think more time is spent
> in copying read-only coordinates for the sake of memory management
> while the JTS counterpart passes pointers around and delegates memory management
> to the garbage collector.
Indeed there are not that much containers heap-allocated. Though some
might be in performance sensitive areas (AbstractNode ? BufferBuilder ?).
> ~/dev/geos/trunk $ grep 'new std' `find . -iname '*.cpp'`
> ./capi/geos_ts_c.cpp: std::vector<Geometry*>* vgeoms = new std::vector<Geometry*>(geoms, geoms + ngeoms);
> ./capi/geos_ts_c.cpp: std::vector<Geometry*> *polyvec = new std::vector<Geometry *>(polys->size());
> ./capi/geos_ts_c.cpp: std::vector<Geometry*> *linevec = new std::vector<Geometry *>(lines->size());
> ./capi/geos_ts_c.cpp: std::vector<Geometry *>*geoms = new std::vector<Geometry *>(lines->size());
> ./capi/geos_ts_c.cpp: std::vector<Geometry *> *vholes = new std::vector<Geometry *>(holes, holes + nholes);
> ./tests/unit/geom/CoordinateListTest.cpp: std::auto_ptr< std::vector<Coordinate> > col( new std::vector<Coordinate>() );
> ./tests/unit/geom/CoordinateArraySequenceTest.cpp: std::vector<Coordinate>* col = new std::vector<Coordinate>();
> ./tests/unit/geom/GeometryFactoryTest.cpp: std::vector<GeometryPtr>* vec = new std::vector<GeometryPtr>();
> ./tests/unit/geom/GeometryFactoryTest.cpp: std::vector<GeometryPtr>* lines = new std::vector<GeometryPtr>();
> ./tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp: std::vector<Coordinate>* col = new std::vector<Coordinate>();
> ./tests/xmltester/XMLTester.cpp: std::vector<geom::Geometry *>*newgeoms = new std::vector<geom::Geometry *>;
> ./tests/xmltester/XMLTester.cpp: std::vector<geom::Geometry *>*newgeoms = new std::vector<geom::Geometry *>(lines->begin(),
> ./source/index/strtree/AbstractNode.cpp: childBoundables=new std::vector<Boundable*>();
> ./source/operation/polygonize/PolygonizeGraph.cpp: intNodes=new std::vector<Node*>();
> ./source/operation/polygonize/PolygonizeGraph.cpp: std::vector<EdgeRing*> *edgeRingList=new std::vector<EdgeRing*>();
> ./source/operation/polygonize/PolygonizeGraph.cpp: std::vector<PolygonizeDirectedEdge*> *edgeRingStarts=new std::vector<PolygonizeDirectedEdge*>();
> ./source/operation/polygonize/PolygonizeGraph.cpp: std::vector<const LineString*> *cutLines=new std::vector<const LineString*>();
> ./source/operation/polygonize/PolygonizeGraph.cpp: std::vector<DirectedEdge*> *edges=new std::vector<DirectedEdge*>();
> ./source/operation/polygonize/PolygonizeGraph.cpp: std::vector<const LineString*> *dangleLines=new std::vector<const LineString*>();
> ./source/operation/buffer/BufferBuilder.cpp: new std::vector< Geometry * >();
> ./source/operation/buffer/BufferBuilder.cpp: std::vector< Geometry* >* mergedLinesGeom = new std::vector< Geometry* >();
> ./source/operation/valid/ConnectedInteriorTester.cpp: std::vector<EdgeRing*> *edgeRings=new std::vector<EdgeRing*>();
> ./source/geomgraph/DirectedEdgeStar.cpp: resultAreaEdgeList=new std::vector<DirectedEdge*>();
> ./source/noding/MCIndexSegmentSetMutualIntersector.cpp:: monoChains( new std::vector<index::chain::MonotoneChain *>()),
> ./source/planargraph/Node.cpp: std::vector<Edge*>* commonEdges = new std::vector<Edge*>();
Maxime
