[geos-devel] RE: {SPAM: 40} :Re: autogen.bat
Obe, Regina
robe.dnd at cityofboston.gov
Thu Nov 19 22:23:48 EST 2009
Those only work for Linux boxes I think. So I had to download the autoexec.bat and run that against my tar download to get it to compile under VS 2008 C++ Express. I'll have to try with the solution files on my other box as I don't recall ever having to do this before. Then again in prior versions the tar ball was broken so wouldn't compile under VS anyway so I always had to use subversion version.
The frustrations of being a citizen of the evil empire :)
Thanks,
Regina
________________________________________
Sent: Thursday, November 19, 2009 4:41 PM
To: Mateusz Loskot; Obe, Regina
Cc: GEOS Development List
Subject: {SPAM: 40} :Re: autogen.bat
On Tue, Nov 17, 2009 at 11:16:28PM +0000, Mateusz Loskot wrote:
> I assumed that GEOS distribution is supposed to already
> provide generated and valid version.h and platform.h and geos_c.h
Uhm, those are distributed indeed.
Regina, do you still need autogen.bat to complete a build out-of-the-box ?
--strk;
Free GIS & Flash consultant/developer () ASCII Ribbon Campaign
http://foo.keybit.net/~strk/services.html /\ Keep it simple!
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
