[geos-devel] [GEOS] #302: trunk build fails
GEOS geos-trac at osgeo.org
Thu Nov 26 18:17:32 EST 2009
 Reporter:  darkblueb   |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 debian 5.03
 Linux aced 2.6.26-2-amd64 #1 SMP Thu Nov 5 02:23:12 UTC 2009 x86_64
 GNU/Linux
 there is something amiss with the overlay dir..
 make fails saying there is no rule to make FuzzyPointLocator, the first of
 three files there
 by creating sym links in the parent dir to the 3 cpp files, you can fool
 make to complete
 but then a similar and parallel fail happens with make check
 g++ -DHAVE_CONFIG_H -I. -I../../source/headers -I../../source/headers/geos
 -I../../source/headers -I../../tests/unit/tut -I../../capi    -g -O2
 -DGEOS_INLINE  -pedantic -Wall -ansi -Wno-long-long  -ffloat-store -MT
 IsSimpleOpTest.o -MD -MP -MF .deps/IsSimpleOpTest.Tpo -c -o
 IsSimpleOpTest.o `test -f 'operation/IsSimpleOpTest.cpp' || echo
 './'`operation/IsSimpleOpTest.cpp
 mv -f .deps/IsSimpleOpTest.Tpo .deps/IsSimpleOpTest.Po
 make[3]: *** No rule to make target
 `operation/overlay/FuzzyPointLocatorTest.cpp', needed by
 `FuzzyPointLocatorTest.o'.  Stop.
Ticket URL: <http://trac.osgeo.org/geos/ticket/302>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
