[geos-devel] Re: [GEOS] #302: trunk build fails
GEOS geos-trac at osgeo.org
Thu Nov 26 20:45:38 EST 2009
 Reporter:  darkblueb   |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  closed
 Priority:  major       |    Milestone:
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:  worksforme
 Keywords:              |
Changes (by darkblueb):
  * status:  reopened => closed
  * resolution:  => worksforme
Comment:
 Replying to [comment:3 pramsey]:
 > Got nothing for you then, since to confirm current state I did the same
 thing on my system (checkout, gen, config, build) and everything ran to
 completion. Can you work back to a commit that caused the state change?
 just when you think you have it, dept.
 rev. 2748
 now working...
Ticket URL: <http://trac.osgeo.org/geos/ticket/302#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
