[geos-devel] Holes in holes
Frederik Ramm frederik at remote.org
Thu Nov 26 20:47:17 EST 2009
Sandro,
Sandro Santilli wrote:
> A polygon with an hole in an hole is a multipolygon formed by a
> and another polygon inside that hole. It is OGC-valid.
Thank you.
I have another remotely related question, that concerns the direction of
a polygon ring (CW or CCW). When I create a polygon with the
createPolygon factory method and pass it a number of rings, do I have to
take care that they spin in the right direction, or will GEOS make sure
that a correct polygon is created?
If I understand the OGC docs correctly, the actual direction does not
matter but they require holes to spin the other way than exterior rings?
Bye
Frederik
Frederik Ramm  ##  eMail frederik at remote.org  ##  N49°00'09" E008°23'33"
