[geos-devel] Re: [GEOS] #222: GEOS 3.0 won't link on ARM-EABI platform
GEOS geos-trac at osgeo.org
Tue Oct 6 19:23:22 EDT 2009
 Reporter:  jcrepetto  |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect     |       Status:  new
 Priority:  major      |    Milestone:  3.3.0
Component:  Default    |      Version:  3.1.1
 Severity:  Critical   |   Resolution:
 Keywords:             |
Changes (by letop):
  * version:  3.0.0 => 3.1.1
Comment:
 > I'd suggest to check if this is the same problem you're dealing with. I
 guess it is, and I'm afraid GEOS has nothing to do with it.
 I have the same problem (on Synology platform).
 I do not the problem is the same as the one you reference.  It is rather a
 double definition in the .o files .
 I did not pinpoint the exact problem but commenting the line in
 inlines.cpp:
 //#include <geos/noding/snapround/MCIndexSnapRounder.inl>
 fixes the issue.
 I have this issue in 3.1.1
Ticket URL: <http://trac.osgeo.org/geos/ticket/222#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
