[geos-devel] Re: [GEOS] #276: "make check" failed at geos_unit on
mingw
geos-trac at osgeo.org
Mon Oct 12 04:30:01 EDT 2009
#276: "make check" failed at geos_unit on mingw
Reporter: sanak | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 3.2.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution:
Keywords: mingw |
Comment (by sanak):
strk,
> Sanak, does the crash still occur with r2669 ?
Yes, it still occur with r2669.
> Can you attach a backtrace ?
When I build geos trunk(r2669) for gdb(backtrace) with "-g"
option(./configure CXXFLAGS="-g" && make && make check), xmltester crash
at heisenbugs.xml and stmlf-cases-20070119.xml.
* XMLTester gdb output
$ gdb ./XMLTester
GNU gdb 6.3
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you
are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for
details.
This GDB was configured as "i686-pc-mingw32"...(no debugging symbols
found)
(gdb) run ./tests/fme.xml
Starting program: e:\mingw\geos-trunk\tests\xmltester/./XMLTester.exe
./tests/fme.xml
Files: 1
Tests: 1
Failed: 0
Succeeded: 1
Program exited normally.
(gdb) run ./tests/heisenbugs.xml
Program exited with code 030000000005.
(gdb) backtrace
(gdb) No stack.
(gdb) No stack.
run ./tests/stmlf/stmlf-cases-20070119.xml
(gdb) backtrace
(gdb) No stack.
And, geos_unit didn't crash. (but linearref::LocationIndexedLine assertion
failed as follows.)
* geos_unit output
geos::io::WKBReader: .......
geos::linearref::LocationIndexedLine: ..........[11=F].............
geos::noding::BasicSegmentString: ....
geos::noding::NodedSegmentString: .....
---> group: geos::linearref::LocationIndexedLine, test: test<11>
problem: assertion failed
tests summary: failures:1 ok:540
FAIL: geos_unit.exe
> Which version of mingw are you using ? Which version of GCC does it
contain ?
I use MinGW-5.1.4 and g++(GCC)-3.4.5 (mingw-vista special r3) on Windows
XP SP3. (I had followed the PostGIS Windows compilation
guide(http://trac.osgeo.org/postgis/wiki/UsersWikiWinCompile ))
Is there person who had succeeded "make check" on Windows MinGW
environment?
And, should I change this Milestone from 3.2.0 to 3.3.0?
Regards,
Ticket URL: <http://trac.osgeo.org/geos/ticket/276#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
