[geos-devel] Re: [GEOS] #283: Patch: ported linearref from JTS
GEOS geos-trac at osgeo.org
Fri Oct 23 06:00:39 EDT 2009
 Reporter:  novalis     |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  reopened
 Priority:  major       |    Milestone:  3.2.0
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Changes (by strk):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 FYI: the code applied contains memory errors and leaks.
 I'll spend some hours on that, but dunno if I've enough funding to
 complete it.
Ticket URL: <http://trac.osgeo.org/geos/ticket/283#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
