[geos-devel] Re: [GEOS] #287: Shouldn't GEOS 3.1 branch be bumped
to 3.1.2
geos-trac at osgeo.org
Fri Sep 11 14:59:19 EDT 2009
#287: Shouldn't GEOS 3.1 branch be bumped to 3.1.2
Reporter: robe | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: trivial | Milestone: 3.1.2
Component: Default | Version: 3.1.1
Severity: Unassigned | Resolution:
Keywords: |
Comment (by pramsey):
We have not used this process in the past, as almost nobody uses svn
versions in settings where they might become confused. Basically, version
numbers are a deployment concern, not a development concern. The version
number is not bumped up until the release process.
Ticket URL: <http://trac.osgeo.org/geos/ticket/287#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
