[geos-devel] Re: [GEOS] #320: factory for std::vector
geos-trac at osgeo.org
Thu Apr 8 04:47:11 EDT 2010
Reporter: 12345678 | Owner: geos-devel at lists.osgeo.org
Type: task | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.2.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by mloskot):
I confirm this is potentially an issue in cases where a factory functions
take ownership of passed collection. For example:
class GEOS_DLL GeometryFactory {
public:
MultiLineString* createMultiLineString(std::vector<Geometry *> *newLines)
const;
If client will allocate the ''newLines'' in EXE/DLL module and pass it to
GEOS DLL module which later will deallocate it, then memory is
[http://blogs.msdn.com/oldnewthing/archive/2006/09/15/755966.aspx
allocated/deallocated across module boundaries] what may lead to problems.
A factory for those containers would be useful indeed.
Ticket URL: <http://trac.osgeo.org/geos/ticket/320#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
