[geos-devel] Re: [GEOS] #358: Invalid output from Union
geos-trac at osgeo.org
Tue Aug 24 04:04:41 EDT 2010
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Comment(by strk):
The attached bug358.xml file is for use within GEOS environment.
You need to build GEOS with GEOS_DEBUG_BINARYOP defined in
include/geos/geom/BinaryOp.h
to see the problem.
For some reason XMLTester --test-valid-output doesn't catch the
invalidity, which should be researched on too...
Ticket URL: <https://trac.osgeo.org/geos/ticket/358#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
