[geos-devel] Re: [GEOS] #358: Invalid output from Union
geos-trac at osgeo.org
Thu Aug 26 20:16:46 EDT 2010
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Comment(by strk):
Alright, the reson why XMLTester --test-valid-output doesn't catch the
invalidity
is because it tests validity of the expected output, not the obtained
output.
Anyway, the problem here is the fact that a valid geometry, when passing
trough
the "common bits adder" procedure becomes invalid.
The invalidity is a collapsed polygon ring (7th inner ring of obtained
result).
POLYGON((1659284.6921065 4797450.16609695,
1659297.0472 4797444.3747,
1659284.6921065 4797450.16609695))
The same ring was NOT invalid when computed, which was, with
removed bits 1659284 4797450:
POLYGON((4500.69210649658 5130.16609695368,
4500.69210649654 5130.16609695368,
4513.04719999991 5124.37470000051,
4500.69210649658 5130.16609695368))
... thus became invalid when summing up bits and discarding
the high precision ones.
Sounds like a conceptually possible thing to happen when
removing and then re-adding precision bits.
Ticket URL: <http://trac.osgeo.org/geos/ticket/358#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
