[geos-devel] Re: [GEOS] #375: Intersection between two valid
geometries yelds an invalid one
geos-trac at osgeo.org
Fri Aug 27 10:47:59 EDT 2010
#375: Intersection between two valid geometries yelds an invalid one
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.0.3
Severity: Unassigned | Keywords:
Comment(by strk):
For the record: refusing an invalid result from the CommonBitsOp policy
thus passing the ball to SnapOp fixes all the stmlf* cases but still
triggers an exception on this one.
At closer look, the SnapOp for this one fails because snapping one of the
geometries makes it invalid (self-intersection).
Computed snap tolerance is 1.1831999999e-07
The two geometries are almost identical, snapping makes a spike collapse
to a line.
Ticket URL: <http://trac.osgeo.org/geos/ticket/375#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
