[geos-devel] Re: [GEOS] #375: Intersection between two valid geometries yelds an invalid one
GEOS geos-trac at osgeo.org
Fri Aug 27 11:57:36 EDT 2010
 Reporter:  strk        |        Owner:  geos-devel@…
     Type:  defect      |       Status:  closed
 Priority:  major       |    Milestone:
Component:  Default     |      Version:  3.0.3
 Severity:  Unassigned  |   Resolution:  wontfix
 Keywords:              |
Changes (by strk):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Let's close this as a wontfix being known to fail in JTS too.
 In it's current incarnation the test is now in failure/TestOverlay.xml
Ticket URL: <http://trac.osgeo.org/geos/ticket/375#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
