[geos-devel] Snapping bug ?
strk strk at keybit.net
Fri Dec 3 05:02:35 EST 2010
On Thu, Dec 02, 2010 at 07:55:06PM -0800, Martin Davis wrote:
> strk,
> I'm not exactly sure which snapping routine you are using (and I'm not
> even sure if GEOS is in synch with JTS for this functionality).
> Can you provide more details on the code you're using?  Is there a
> tolerance involved?
GEOS/JTS in sync
(I checked and synched, only additional snapToSelf was missing).
Tolerance is 1, but 0.6 is also enough.
It's now in postgis too:
=# select st_asewkt(st_snap(
 'POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0))',
 'POINT(0.5 0)',
 0.6
POLYGON((0.5 0,0.5 0,1 1,0 1,0.5 0))
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
