[geos-devel] rgeos interface to R classes (sp, others)
Roger Bivand Roger.Bivand at nhh.no
Mon Feb 1 15:27:31 EST 2010
On Mon, 1 Feb 2010, Martin Davis wrote:
> Can you post the WKT/WKB of your test case?
If this is WKT, then:
> SP2WKT(spol0)
[1] "MULTIPOLYGON(((0 0.1,0 0.2,0.1 0.2,0.1 0.1,0 0.1)),
   ((0.1 0.1,0.1 0.2,0.2 0.2,0.2 0.1,0.1 0.1)),
   ((0 0,0 0.1,0.1 0.1,0.1 0,0 0)))"
> SP2WKT(spolx0)
[1] "MULTIPOLYGON(((0 100,0 200,100 200,100 100,0 100)),
   ((100 100,100 200,200 200,200 100,100 100)),
   ((0 0,0 100,100 100,100 0,0 0)))"
I don't think that there is an OGR driver, is there? So this is a text
representation for the two objects, each with 3 Polygon members, and only
differing in scale (the coordinates of the second are 1000 times those of
the first). I see the same difference on GEOS 3.2.0/C API 1.6.0 on x86_64
RHEL5 and with an MSYS-built GEOS 3.2.0/C API 1.6.0 on Win 32 R.
Hope this is good enough, grateful for any ideas,
Roger
>>> Roger,
>>> The technique of using buffer(0) to union polygons is now deprecated in
>>> favour of using Unary Union (Geometry.union() - not sure what the exact
>>> GEOS signature is).  Unary Union is usually faster and more robust than
>>> the previous technique.  You might want to check this out.
>> Martin,
>> Thanks, I've replaced buffer(0) by GEOSUnionCascaded (C API). But the
>> artefact remains. For input MULTIPOLYGON:
>> I still get the same MultiPolygon out when the bounding box is
>> (0,0)(0.2,0.2), but correctly Polygon:
>> when the bounding box is (0,0)(200,200). May this be related to the input
>> Polygon objects only having 5 coordinates (4 corners and closure)? The
>> generating code is inserting exactly the same doubles into the coordinates.
>> Anyway, I'm sure that Unary Union is a better solution than buffer(0) in
>> general, so thanks for that!
>> Roger
>>> Martin
>>> Roger Bivand wrote:
>>>> Hi,
>>>> I've felt that I've been making reasonable progress with interfacing GEOS
>>>> geometries and methods for the R language (cran.r-project.org), in a
>>>> draft contributed package rgeos:
>>>> https://r-forge.r-project.org/projects/rgeos/
>>>> However, I encountered a problem that I do not understand, and would be
>>>> very grateful if I could be put back on track. The specific problem is
>>>> that an R function uses the C API to dissolve polygon borders for
>>>> adjacent polygons sharing a category given as its second argument.
>>>> I've used the buffer technique from the JTS documentation, and all was
>>>> well until I tried to dissolve borders between touching squares when the
>>>> coordinate measures were small (square side 0.1). When the squares are
>>>> 100 units, all is well, and GEOMTouches is TRUE. But for 0.1, GEOMTouches
>>>> is FALSE, and no dissolving takes place.
>>>> This can be reproduced (I'm on RHEL5, x86_64) by installing R,
>>>> contributed packages sp and maptools from CRAN, GEOS (3.1.1 or 3.2.0),
>>>> and installing rgeos from R-Forge. Start R, say
>>>> library(rgeos) example(unionSpatialPolygonsGEOS)
>>>> and look for undissolved borders in:
>>>> image(grd, axes=TRUE)
>>>> plot(spol1, add=TRUE)
>>>> but dissolved in:
>>>> image(grdx, axes=TRUE)
>>>> plot(spol1x, add=TRUE)
>>>> I started on an alternative implementation using GEOMTouches in
>>>> unionSpatialPolygonsGEOS(..., buffer=FALSE) output to console, where one
>>>> sees in the example output:
>>>>> spol1F <- unionSpatialPolygonsGEOS(as(spol, "SpatialPolygons"),
>>>> +   as.character(spol$xvs), buffer=FALSE)
>>>> # 4 squares within (0,0), (0.2,0.2) NE, NW, SW share category, SE doesn't
>>>> npls: 3, nnpls: 3
>>>> type[0] Polygon
>>>> i: 0, j: 1, touches: 0
>>>> i: 0, j: 2, touches: 0
>>>> type[1] Polygon
>>>> i: 1, j: 2, touches: 0
>>>> type[2] Polygon
>>>> out of function
>>>> npls: 1, nnpls: 1
>>>> type[0] Polygon
>>>> out of function
>>>>> spol1xF <- unionSpatialPolygonsGEOS(as(spolx, "SpatialPolygons"),
>>>> +   as.character(spolx$xvs), buffer=FALSE)
>>>> # 4 squares within (0,0), (200,200), same categories
>>>> npls: 3, nnpls: 3
>>>> type[0] Polygon
>>>> i: 0, j: 1, touches: 1
>>>> i: 0, j: 2, touches: 1
>>>> type[1] Polygon
>>>> i: 1, j: 2, touches: 1
>>>> type[2] Polygon
>>>> out of function
>>>> npls: 1, nnpls: 1
>>>> type[0] Polygon
>>>> out of function
>>>> The C code is in:
>>>> https://r-forge.r-project.org/plugins/scmsvn/viewcvs.php/pkg/src/rgeos_sp.c?rev=44&root=rgeos&view=log
>>>> around line 466 rgeos_SpatialPolygonsUnion(), calling
>>>> rgeos_plspairUnion() - desperate test framework, or rgeos_plsbufUnion()
>>>> which I had thought worked, but which clearly doesn't dissolve small
>>>> squares.
>>>> Very grateful for any help, this is a show-stopper, and I had hoped to
>>>> release rgeos before February (small chance now!)
>>>> Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
