[geos-devel] Unary Union (was: rgeos interface to R classes)
Sandro Santilli strk at keybit.net
Fri Feb 5 08:28:20 EST 2010
On Fri, Feb 05, 2010 at 01:58:14PM +0100, Sandro Santilli wrote:
> On Fri, Feb 5, 2010 at 12:29 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> > Seems to be in the 3.2.0/1.6.0 C API as GEOSUnionCascaded(), and works like
> > the buffer trick for me (except for my unsolved scale problem).
> I've checked the GEOS code. It's actually NOT the same classes being
> used for CascadedUnion and UnaryUnion. Dunno about the actual
> output characteristic, but it's surely documented (in JTS) to be different
> from the buffer trick.
Oope, you were right. At least for polygons, it's the same
of UnionCascaded.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://foo.keybit.net/~strk/services.html
