[geos-devel] What do GEOSSymDifference and GEOSIntersection
(CAPI) do?
strk
strk at keybit.net
Wed Feb 10 06:04:18 EST 2010
On Wed, Feb 10, 2010 at 12:00:31PM +0100, Roger Bivand wrote:
> I've tried to go through GEOSPolygonize() to put the MULTILINESTRING
> together again, and am analysing what has happened, but think that the
> output has lost hole attributions, so needs running through GEOSContains
> or similar.
Oh, if your goal is building an area you may consider
moving the algorithm implemented by PostGIS's ST_BuildArea
code down into the C-API (from the postgis geos wrapper).
I belive it would be useful in general...
--strk;
() Free GIS & Flash consultant/developer
/\ http://foo.keybit.net/~strk/services.html
