[geos-devel] Re: cmake: distclean-like ? out of source tree build ?
strk strk at keybit.net
Wed Feb 10 10:29:19 EST 2010
> > mloskot at dog:~/dev/geos/_svn/trunk$ svn-clean
> By the way, if you are suspicious about some remaining garbage in the
> source tree, just run svn-clean and confirm you have trunk up-to-date
> with nothing reported by svn status.
svn-clean doesn't seem to be part of 'svn' package, do you confirm ?
On an OpenSUSE I'm prompted to install kde-related things ?!
 The program 'svn-clean' can be found in following packages:
   * kdesdk3 [ path: /opt/kde3/bin/svn-clean, repository: zypp (ARKANIS_openSUSE_11.1_1) ]
   * kdesdk4-scripts [ path: /usr/bin/svn-clean, repository: zypp (ARKANIS_openSUSE_11.1_1) ]
 Try installing with: sudo zypper install kdesdk3
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://foo.keybit.net/~strk/services.html
