[geos-devel] Re: [GEOS] #331: Geos build fails on linking on Solaris
GEOS geos-trac at osgeo.org
Fri Feb 12 10:31:16 EST 2010
 Reporter:  sandy2010          |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect             |       Status:  new
 Priority:  major              |    Milestone:
Component:  Default            |      Version:  3.1.1
 Severity:  Critical           |   Resolution:
 Keywords:  sun,solaris,sparc  |
Old description:
> I'm building geos-3.1.1 on Solaris (5.9 sparc and 5.10 x86) and used all
> the 3 patches uploaded by rroliver in ticket #224.
> and I get some issue during link time with multiple symbol definitions.
> When I provide --disable-inline during configure, it gives me the
> following error on linking:
> CC -G -zdefs -hlibgeos-3.1.1.so -o .libs/libgeos-3.1.1.so
> .libs/inlines.o -Qoption ld -z -Qoption ld
> allextract,algorithm/.libs/libalgorithm.a,geom/.libs/libgeom.a,geomgraph/.libs/libgeomgraph.a,index/.libs/libindex.a,io/.libs/libio.a,noding/.libs/libnoding.a,operation/.libs/liboperation.a,planargraph/.libs/libplanargraph.a,precision/.libs/libprecision.a,simplify/.libs/libsimplify.a,util/.libs/libutil.a
> -Qoption ld -z -Qoption ld defaultextract  -lCstd -lCrun -lc
> Undefined                       first referenced
>  symbol                             in file
> cos
> operation/.libs/liboperation.a(OffsetCurveBuilder.o)
> log
> geom/.libs/libgeom.a(PrecisionModel.o)
> pow                                 index/.libs/libindex.a(DoubleBits.o)
> sin
> ceil
> fabs
> algorithm/.libs/libalgorithm.a(CGAlgorithms.o)
> sqrt
> atan2                               geom/.libs/libgeom.a(LineSegment.o)
> floor
> algorithm/.libs/libalgorithm.a(RobustDeterminant.o)
> __fabsl
> algorithm/.libs/libalgorithm.a(HCoordinate.o)
> ld: fatal: Symbol referencing errors. No output written to
> make[2]: *** [libgeos.la] Error 1
> make[2]: Leaving directory `/opt/geos-3.1.1/source'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/opt/geos-3.1.1/source'
> make: *** [all-recursive] Error 1
New description:
  symbol                             in file
 cos    operation/.libs/liboperation.a(OffsetCurveBuilder.o)
 log    geom/.libs/libgeom.a(PrecisionModel.o)
 sin      operation/.libs/liboperation.a(OffsetCurveBuilder.o)
 ceil     geom/.libs/libgeom.a(PrecisionModel.o)
 fabs     algorithm/.libs/libalgorithm.a(CGAlgorithms.o)
 sqrt     algorithm/.libs/libalgorithm.a(CGAlgorithms.o)
 floor    algorithm/.libs/libalgorithm.a(RobustDeterminant.o)
 __fabsl  algorithm/.libs/libalgorithm.a(HCoordinate.o)
Ticket URL: <http://trac.osgeo.org/geos/ticket/331#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
