[geos-devel] Patch to expose more methods in the CAPI
Alex Trofast alex.trofast at ingres.com
Wed Jan 6 11:27:14 EST 2010
Greetings GEOS-devel
I've attached a patch that exposes these C++ class methods as CAPI
functions:
LineString::getPointN -> GEOSGetPointN
LineString::getStartPoint -> GEOSGetStartPoint
LineString::getEndPoint -> GEOSGetEndPoint
LineString::isClosed -> GEOSisClosed
LineString::getLength -> GEOSGetLength
LineString::getNumPoints -> GEOSGetNumPoints
Point::getX -> GEOSGetX
Point::getY -> GEOSGetY
Additionally I wrote a small test case for the new functions. Any
feedback is greatly appreciated.
Thank you,
Alex Trofast
Software Engineer
Ingres
Index: tests/unit/Makefile.am
--- tests/unit/Makefile.am	(revision 2835)
+++ tests/unit/Makefile.am	(working copy)
@@ -90,7 +90,8 @@
 	capi/GEOSSimplifyTest.cpp \
 	capi/GEOSPreparedGeometryTest.cpp \
 	capi/GEOSPolygonizer_getCutEdgesTest.cpp \
-	capi/GEOSBufferTest.cpp
+	capi/GEOSBufferTest.cpp \
+	capi/GEOSLineString_PointTest.cpp
 noinst_HEADERS = \
 	utility.h
Index: tests/unit/capi/GEOSLineString_PointTest.cpp
--- tests/unit/capi/GEOSLineString_PointTest.cpp	(revision 0)
+++ tests/unit/capi/GEOSLineString_PointTest.cpp	(revision 0)
@@ -0,0 +1,123 @@
+// Test Suite for C-API LineString and Point functions
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+namespace tut
+    // Test Group
+    // Common data used in test cases.
+    struct test_capilinestringpoint_data
+        GEOSGeometry* geom1_;
+        static void notice(const char *fmt, ...)
+            std::fprintf( stdout, "NOTICE: ");
+            va_list ap;
+            va_start(ap, fmt);
+            std::vfprintf(stdout, fmt, ap);
+            va_end(ap);
+            std::fprintf(stdout, "\n");
+        test_capilinestringpoint_data()
+            : geom1_(0)
+            initGEOS(notice, notice);
+        ~test_capilinestringpoint_data()
+            GEOSGeom_destroy(geom1_);
+            geom1_ = 0;
+            finishGEOS();
+    typedef test_group<test_capilinestringpoint_data> group;
+    typedef group::object object;
+    group test_capilinestringpoint_group("capi::GEOSLineStringPoint");
+    // Test Cases
+    template<>
+    template<>
+    void object::test<1>()
+        geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, 5 5, 10 10)");
+        GEOSGeometry *geom2;
+        double x, y;
+        ensure( 0 != geom1_ );
+        char const r1 = GEOSisClosed(geom1_);
+        ensure_equals(r1, 0);
+        geom2 = GEOSGetPointN(geom1_, 0);
+        GEOSGetX(geom2, &x);
+        GEOSGetY(geom2, &y);
+        ensure_equals(x, 0);
+        ensure_equals(y, 0);
+        GEOSGeom_destroy(geom2);
+        geom2 = GEOSGetStartPoint(geom1_);
+        geom2 = GEOSGetEndPoint(geom1_);
+        ensure_equals(x, 10);
+        ensure_equals(y, 10);
+    template<>
+    template<>
+    void object::test<2>()
+        double length;
+        GEOSGetLength(geom1_, &length);
+        ensure(length != 0.0);
+    template<>
+    template<>
+    void object::test<3>()
+        int points;
+        points = GEOSGetNumPoints(geom1_);
+        ensure_equals(points, 3);
+} // namespace tut
Index: capi/geos_c.cpp
--- capi/geos_c.cpp	(revision 2835)
+++ capi/geos_c.cpp	(working copy)
@@ -452,8 +452,85 @@
     return GEOSGetGeometryN_r( handle, g1, n );
+ * Call only on LINESTRING
+ * Returns NULL on exception
+Geometry *
+GEOSGetPointN(const Geometry *g1, int n)
+	return GEOSGetPointN_r(handle, g1, n);
+Geometry *
+GEOSGetStartPoint(const Geometry *g1)
+	return GEOSGetStartPoint_r(handle, g1);
+Geometry *
+GEOSGetEndPoint(const Geometry *g1)
+	return GEOSGetEndPoint_r(handle, g1);
+ * return 2 on exception, 1 on true, 0 on false
+char
+GEOSisClosed(const Geometry *g1)
+	return GEOSisClosed_r(handle, g1);
+ * returns 0 on exception, otherwise 1
+int
+GEOSGetLength(const Geometry *g1, double *length)
+	return GEOSGetLength_r(handle, g1, length);
+ * returns -1 on exception
+int
+GEOSGetNumPoints(const Geometry *g1)
+	return GEOSGetNumPoints_r(handle, g1);
+ * For POINT
+int
+GEOSGetX(const Geometry *g1, double *x)
+	return GEOSGetX_r(handle, g1, x);
+ * For POINT
+int
+GEOSGetY(const Geometry *g1, double *y)
+	return GEOSGetY_r(handle, g1, y);
  * Call only on polygon
  * Return a copy of the internal Geometry.
Index: capi/geos_ts_c.cpp
--- capi/geos_ts_c.cpp	(revision 2835)
+++ capi/geos_ts_c.cpp	(working copy)
@@ -1991,8 +1991,343 @@
     return NULL;
+Geometry *
+GEOSGetPointN_r(GEOSContextHandle_t extHandle, const Geometry *g1, int n)
+    if ( 0 == extHandle )
+        return NULL;
+    GEOSContextHandleInternal_t *handle = 0;
+    handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+    if ( 0 == handle->initialized )
+        return NULL;
+    try
+    	using geos::geom::LineString;
+    	const LineString *ls = dynamic_cast<const LineString *>(g1);
+    	if ( ! ls )
+    		handle->ERROR_MESSAGE("Argument is not a LineString");
+    		return NULL;
+    	return ls->getPointN(n);
+    catch (const std::exception &e)
+        handle->ERROR_MESSAGE("%s", e.what());
+    catch (...)
+        handle->ERROR_MESSAGE("Unknown exception thrown");
+    return NULL;
+Geometry *
+GEOSGetStartPoint_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+        return NULL;
+        return NULL;
+    try
+    	if ( ! ls )
+    		return NULL;
+    	return ls->getStartPoint();
+    catch (...)
+    return NULL;
+Geometry *
+GEOSGetEndPoint_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+        return NULL;
+        return NULL;
+    try
+    	if ( ! ls )
+    		return NULL;
+    	return ls->getEndPoint();
+    catch (...)
+    return NULL;
+char
+GEOSisClosed_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+        return 2;
+        return 2;
+    try
+    	if ( ! ls )
+    		return 2;
+    	return ls->isClosed();
+    catch (...)
+    return 2;
+ * return 0 on exception, otherwise 1
+int
+GEOSGetLength_r(GEOSContextHandle_t extHandle, const Geometry *g1, double *length)
+        return 0;
+        return 0;
+    try
+    	if ( ! ls )
+    		return 0;
+    	*length = ls->getLength();
+    	return 1;
+    catch (...)
+    return 0;
+int
+GEOSGetNumPoints_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+        return -1;
+        return -1;
+    try
+		if ( ! ls )
+			return -1;
+		return ls->getNumPoints();
+    catch (...)
+    return -1;
+ * For POINT
+int
+GEOSGetX_r(GEOSContextHandle_t extHandle, const Geometry *g1, double *x)
+        return 0;
+        return 0;
+    try
+    	using geos::geom::Point;
+    	const Point *po = dynamic_cast<const Point *>(g1);
+    	if ( ! po )
+    		handle->ERROR_MESSAGE("Argument is not a Point");
+    		return 0;
+    	*x = po->getX();
+    	return 1;
+    catch (...)
+    return 0;
+ * For POINT
+int
+GEOSGetY_r(GEOSContextHandle_t extHandle, const Geometry *g1, double *y)
+        return 0;
+        return 0;
+    try
+    	if ( ! po )
+    		return 0;
+    	*y = po->getY();
+    	return 1;
+    catch (...)
+    return 0;
Index: capi/geos_c.h.in
--- capi/geos_c.h.in	(revision 2835)
+++ capi/geos_c.h.in	(working copy)
@@ -687,6 +687,7 @@
 extern char GEOS_DLL GEOSisSimple(const GEOSGeometry* g1);
 extern char GEOS_DLL GEOSisRing(const GEOSGeometry* g1);
 extern char GEOS_DLL GEOSHasZ(const GEOSGeometry* g1);
+extern char GEOS_DLL GEOSisClosed(const GEOSGeometry *g1);
 extern char GEOS_DLL GEOSisEmpty_r(GEOSContextHandle_t handle,
@@ -700,6 +701,8 @@
 extern char GEOS_DLL GEOSHasZ_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSisClosed_r(GEOSContextHandle_t handle,
+                                const GEOSGeometry *g1);
@@ -762,6 +765,19 @@
 extern int GEOS_DLL GEOSGetNumInteriorRings_r(GEOSContextHandle_t handle,
+/* Return -1 on exception, Geometry must be a LineString. */
+extern int GEOS_DLL GEOSGetNumPoints(const GEOSGeometry* g1);
+extern int GEOS_DLL GEOSGetNumPoints_r(GEOSContextHandle_t handle,
+                                       const GEOSGeometry* g1);
+/* Return -1 on exception, Geometry must be a Point. */
+extern int GEOS_DLL GEOSGetX(const GEOSGeometry *g1, double *x);
+extern int GEOS_DLL GEOSGetY(const GEOSGeometry *g1, double *y);
+extern int GEOS_DLL GEOSGetX_r(GEOSContextHandle_t handle, const GEOSGeometry *g1, double *x);
+extern int GEOS_DLL GEOSGetY_r(GEOSContextHandle_t handle, const GEOSGeometry *g1, double *y);
  * Return NULL on exception, Geometry must be a Polygon.
  * Returned object is a pointer to internal storage:
@@ -809,6 +825,18 @@
 extern int GEOS_DLL GEOSGeom_getDimensions_r(GEOSContextHandle_t handle,
                                              const GEOSGeometry* g);
+ * Return NULL on exception.
+ * Must be LineString and must be freed by called.
+extern GEOSGeometry GEOS_DLL *GEOSGetPointN(const GEOSGeometry *g1, int n);
+extern GEOSGeometry GEOS_DLL *GEOSGetStartPoint(const GEOSGeometry *g1);
+extern GEOSGeometry GEOS_DLL *GEOSGetEndPoint(const GEOSGeometry *g1);
+extern GEOSGeometry GEOS_DLL *GEOSGetPointN_r(GEOSContextHandle_t handle, const GEOSGeometry *g1, int n);
+extern GEOSGeometry GEOS_DLL *GEOSGetStartPoint_r(GEOSContextHandle_t handle, const GEOSGeometry *g1);
+extern GEOSGeometry GEOS_DLL *GEOSGetEndPoint_r(GEOSContextHandle_t handle, const GEOSGeometry *g1);
  *  Misc functions
@@ -824,6 +852,7 @@
         const GEOSGeometry *g2, double *dist);
 extern int GEOS_DLL GEOSHausdorffDistanceDensify(const GEOSGeometry *g1,
         const GEOSGeometry *g2, double densifyFrac, double *dist);
+extern int GEOS_DLL GEOSGetLength(const GEOSGeometry *g1, double *length);
 extern int GEOS_DLL GEOSArea_r(GEOSContextHandle_t handle,
                                const GEOSGeometry* g1, double *area);
 extern int GEOS_DLL GEOSLength_r(GEOSContextHandle_t handle,
@@ -839,6 +868,8 @@
+extern int GEOS_DLL GEOSGetLength_r(GEOSContextHandle_t handle,
+                                   const GEOSGeometry *g1, double *length);
