[geos-devel] Re: [GEOS] #299:
geos::geom::CoordinateArraySequenceFactory unit test failing
geos-trac at osgeo.org
Sat Jan 9 12:27:39 EST 2010
#299: geos::geom::CoordinateArraySequenceFactory unit test failing
Reporter: pramsey | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 3.3.0
Component: Unit Tests | Version: svn-trunk
Severity: Unassigned | Resolution:
Keywords: |
Changes (by mloskot):
* owner: => geos-devel at lists.osgeo.org
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:17>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
