[geos-devel] Topology Exception with nested collections
Obe, Regina robe.dnd at cityofboston.gov
Wed Jan 20 14:41:26 EST 2010
I'm actually not sure if this is a bug or not, but I always thought in a perfect world that if I union two valid geometries, I should not get errors.  I get a bunch of these in my torture tests (both against 3.1.1 and 3.2.0 GEOS) and verified they  pass the ST_IsValid test.
One of these cases stripped down to its bear minimum - gives error :
NOTICE:  TopologyException: side location conflict -9 50 --.  Anyway thought I would mention it in case its not a trivial thing.  I doubt anyone has monsters like this anyway.
SELECT ST_Union(foo1.geom, foo2.geom)
FROM (SELECT ST_GeomFromEWKT('SRID=4326;GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(-10 50),POLYGON((-9 50,51 -11,-10 50,-9 50))),GEOMETRYCOLLECTION(POINT(-10 70),POLYGON((-9 70,71 -11,-10 70,-9 70))),GEOMETRYCOLLECTION(POINT(-10 50),POLYGON((-8 50,52 -12,-10 50,-8 50))),GEOMETRYCOLLECTION(POINT(-10 70),POLYGON((-8 70,72 -12,-10 70,-8 70))),GEOMETRYCOLLECTION(POINT(10 50),POLYGON((11 50,51 9,10 50,11 50))),GEOMETRYCOLLECTION(POINT(10 70),POLYGON((11 70,71 9,10 70,11 70))),GEOMETRYCOLLECTION(POINT(10 50),POLYGON((12 50,52 8,10 50,12 50))),GEOMETRYCOLLECTION(POINT(10 70),POLYGON((12 70,72 8,10 70,12 70))),GEOMETRYCOLLECTION(POINT(30 50),POLYGON((31 50,51 29,30 50,31 50))),GEOMETRYCOLLECTION(POINT(30 70),POLYGON((31 70,71 29,30 70,31 70))),GEOMETRYCOLLECTION(POINT(30 50),POLYGON((32 50,52 28,30 50,32 50))),GEOMETRYCOLLECTION(POINT(30 70),POLYGON((32 70,72 28,30 70,32 70))),GEOMETRYCOLLECTION(POINT(50 50),POLYGON((51 50,51 49,50 50,51 50))),GEOMETRYCOLLECTION(POINT(50 70),POLYGON((51 70,71 49,50 70,51 70))),GEOMETRYCOLLECTION(POINT(50 50),POLYGON((52 50,52 48,50 50,52 50))),GEOMETRYCOLLECTION(POINT(50 70),POLYGON((52 70,72 48,50 70,52 70))))') As geom) As foo1
	CROSS JOIN
	(SELECT ST_GeomFromEWKT('SRID=4326;GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(-10 50),POLYGON((-9 50,51 -11,-10 50,-9 50))),GEOMETRYCOLLECTION(POINT(-10 70),POLYGON((-9 70,71 -11,-10 70,-9 70))),GEOMETRYCOLLECTION(POINT(-10 50),POLYGON((-8 50,52 -12,-10 50,-8 50))),GEOMETRYCOLLECTION(POINT(-10 70),POLYGON((-8 70,72 -12,-10 70,-8 70))),GEOMETRYCOLLECTION(POINT(10 50),POLYGON((11 50,51 9,10 50,11 50))),GEOMETRYCOLLECTION(POINT(10 70),POLYGON((11 70,71 9,10 70,11 70))),GEOMETRYCOLLECTION(POINT(10 50),POLYGON((12 50,52 8,10 50,12 50))),GEOMETRYCOLLECTION(POINT(10 70),POLYGON((12 70,72 8,10 70,12 70))),GEOMETRYCOLLECTION(POINT(30 50),POLYGON((31 50,51 29,30 50,31 50))),GEOMETRYCOLLECTION(POINT(30 70),POLYGON((31 70,71 29,30 70,31 70))),GEOMETRYCOLLECTION(POINT(30 50),POLYGON((32 50,52 28,30 50,32 50))),GEOMETRYCOLLECTION(POINT(30 70),POLYGON((32 70,72 28,30 70,32 70))),GEOMETRYCOLLECTION(POINT(50 50),POLYGON((51 50,51 49,50 50,51 50))),GEOMETRYCOLLECTION(POINT(50 70),POLYGON((51 70,71 49,50 70,51 70))),GEOMETRYCOLLECTION(POINT(50 50),POLYGON((52 50,52 48,50 50,52 50))),GEOMETRYCOLLECTION(POINT(50 70),POLYGON((52 70,72 48,50 70,52 70))))') As geom) As foo2
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
