[geos-devel] Re: Polygonizer bug ?
strk
strk at keybit.net
Thu Jul 1 17:48:32 EDT 2010
FYI, as of r3078 the mis-port is fixed in GEOS.
Still interested in the result after self-noding.
Thanks !
--strk;
On Thu, Jul 01, 2010 at 10:59:12PM +0200, strk wrote:
> On Mon, Jun 21, 2010 at 09:13:16AM -0700, Martin Davis wrote:
> > strk,
> > The JTS Developer's Guide is a bit confusing. The geometry given in the
> > example is NOT the geometry depicted in the illustration. (This is a
> > doc bug - but I"m not sure if and when I can fix it).
> > When I run the geometry below in JTS I get:
> > Polygons:
> > GEOMETRYCOLLECTION (
> > POLYGON ((189 98, 83 187, 185 221, 325 168, 189 98)),
> > POLYGON ((185 221, 88 275, 180 316, 292 281, 185 221)))
> > Dangles:
> > MULTILINESTRING ((185 221, 100 100),
> > (0 0, 10 10))
> > I believe this is the expected result.
> Uhm, that's w/out self-noding, right ?
> --strk;
> > Hope that helps
> > Martin
> > strk wrote:
> > >Martin, I'm adding a testcase for the Polygonizer using example from :
> > >"JTS Developer's Guide, Chapter 6 - Polygonization"
> > >Here's the input, represented as a collection:
> > >GEOMETRYCOLLECTION(
> > > LINESTRING(0 0, 10 10),
> > > LINESTRING(185 221, 100 100),
> > > LINESTRING(185 221, 88 275, 180 316),
> > > LINESTRING(185 221, 292 281, 180 316),
> > > LINESTRING(189 98, 83 187, 185 221),
> > > LINESTRING(189 98, 325 168, 185 221))
> > >When passing it into the Polygonizer class I get
> > >2 rings, no cut or invalid edges and 3 dangles.
> > >Also notable is that of the 3 dangles, 2 are identical
> > >and specificall are the isolated edge (first geometry
> > >in the collection).
> > >The example in the guide suggests the rings should
> > >be 3 instead, and that there should be one cut
> > >edge (represented in blue) and 2 dangles
> > >the red ones.
> > >Does it sound as a bug in GEOS or does JTS give the
> > >same results ?
> > >Note that forcing proper noding using the union trick
> > >does give the 3 expected rings, but still lacks the
> > >cut edge and duplicates the dangle.
> > >Thanks in advance.
> > >--strk;
> > > () Free GIS & Flash consultant/developer
> > > /\ http://strk.keybit.net/services.html
> > Martin Davis
> > Senior Technical Architect
> > Refractions Research, Inc.
> > (250) 383-3022
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
