[geos-devel] [GEOS] #362: Build fails on libtool/capi
GEOS geos-trac at osgeo.org
Tue Jul 13 14:57:25 EDT 2010
 Reporter:  chodgson    |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.2.0
 Severity:  Unassigned  |    Keywords:
 Downloaded 3.2.2 source tarball. Running on Redhat linux el5,
 2.6.18-164.15.1.el5, x86_64
 Configured with:
 ./configure --prefix=/usr/local/ --libdir=/usr/local/lib64
 make command ends with:
 Making all in capi
 make[1]: Entering directory `/usr/local/src/geos-3.2.2/capi'
 /bin/sh ../libtool --tag=CXX   --mode=link g++  -DGEOS_INLINE  -pedantic
 -Wall -ansi -Wno-long-long  -ffloat-store -version-info 7:2:6 -no-
 undefined  -o libgeos_c.la -rpath /usr/local/lib64 libgeos_c_la-geos_c.lo
 libgeos_c_la-geos_ts_c.lo ../source/libgeos.la
 libtool: link: unsupported hardcode properties
 libtool: link: See the libtool documentation for more information.
 libtool: link: Fatal configuration error.
 make[1]: *** [libgeos_c.la] Error 1
 make[1]: Leaving directory `/usr/local/src/geos-3.2.2/capi'
 make: *** [all-recursive] Error 1
 The same configure options compiles successfully using the 3.2.1 source
 tarball. Am I doing something weird or is x86_64 not that well tested?
Ticket URL: <http://trac.osgeo.org/geos/ticket/362>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
