[geos-devel] Re: [GEOS] #362: Build fails on libtool/capi
geos-trac at osgeo.org
Tue Jul 13 17:09:03 EDT 2010
Reporter: chodgson | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: 3.2.0
Severity: Unassigned | Keywords:
Comment(by chodgson):
Hmm... without the libdir it seems to work fine.. however I had a
situation before when building a full mapserver/gdal/geos/postgis/proj/etc
stack that things didn't work right if I didn't put them in the lib64 dir.
I think it may have been gdal that was picky about that and I'm not using
gdal for this build so I think can leave it out... kinda weird that I get
this error from a simple directory option though.
Ticket URL: <http://trac.osgeo.org/geos/ticket/362#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
