[geos-devel] [GEOS] #365: build fails with mingw
GEOS geos-trac at osgeo.org
Wed Jul 21 02:18:23 EDT 2010
 Reporter:  nicklas     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:  mingw
 make fails with the error-message
 "Can not compile without isnan function or macro"
 it is in file platform.h
 The attached patch seems to solve the problem.
 In 3.2.2 was no conditions to use the OS/X "hack" so I guess also mingw
 did.
 /Nicklas
Ticket URL: <http://trac.osgeo.org/geos/ticket/365>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
