[geos-devel] [GEOS] #351: Missing includes
geos-trac at osgeo.org
Mon Jun 14 09:57:19 EDT 2010
Reporter: yabo | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
svn_trunk fails to build on my platform (Linux 64bit, g++ 4.4.3). The
errors where about the function isnan and the assert macro.
Here are the changes I had to make :
* Add <cmath> include to
* src/geom/GeometryFactory.cpp
* src/geom/CoordinateArraySequence.cpp
* src/io/WKTWriter.cpp
* Add <cassert> include to
* include/geos/operation/buffer/OffsetCurveVertexList.h
$ svn diff
Index: src/geom/CoordinateArraySequence.cpp
--- src/geom/CoordinateArraySequence.cpp (revision 2999)
+++ src/geom/CoordinateArraySequence.cpp (working copy)
@@ -24,6 +24,7 @@
#include <cassert>
#include <algorithm>
#include <vector>
+#include <cmath>
using namespace std;
Index: src/geom/GeometryFactory.cpp
--- src/geom/GeometryFactory.cpp (revision 2999)
+++ src/geom/GeometryFactory.cpp (working copy)
@@ -37,6 +37,7 @@
#include <cassert>
#include <vector>
#include <typeinfo>
+#include <cmath>
#ifndef GEOS_DEBUG
#define GEOS_DEBUG 0
Index: src/io/WKTWriter.cpp
--- src/io/WKTWriter.cpp (revision 2999)
+++ src/io/WKTWriter.cpp (working copy)
@@ -37,6 +37,7 @@
#include <string>
#include <sstream>
#include <cassert>
+#include <cmath>
using namespace geos::geom;
Index: include/geos/operation/buffer/OffsetCurveVertexList.h
--- include/geos/operation/buffer/OffsetCurveVertexList.h (revision
2999)
+++ include/geos/operation/buffer/OffsetCurveVertexList.h (working
copy)
@@ -27,6 +27,7 @@
#include <vector>
#include <memory>
+#include <cassert>
// Forward declarations
namespace geos {
Ticket URL: <http://trac.osgeo.org/geos/ticket/351>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
