[geos-devel] [GEOS] #352: make dist does not package swig binding
GEOS geos-trac at osgeo.org
Wed Jun 16 05:23:08 EDT 2010
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 ... unless you configured with --enable-xxxxy
 the DIST_SUBDIRS variable for Makefile.am would fix this
 this item is just so we don't forget
Ticket URL: <http://trac.osgeo.org/geos/ticket/352>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
