[geos-devel] PHP bindings
strk strk at keybit.net
Fri Jun 18 12:41:47 EDT 2010
So, current trunk as a -std=gnu99 added to CFLAGS
when building the PHP bindings and was tested to
work on OpenSUSE 11.1 and Ubuntu 8.10 with gcc-4.3.2
(-std=c99 didn't work on the Ubuntu box).
If anyone feels like testing on other systems these
are the steps:
	0: svn up
	1: make sure you have php5 dev files
	   installed (for debian-based: apt-get install php5-dev)
	2: ./autogen.sh && ./configure --enable-php
	3: make
	4: make check (bonus)
Bonus step 4 you may want to run under php/ dir only.
If you get lots of errors in step 3 that's likely Zend
interaction with -ansi, which is what I'm trying to
fix in a general way.
--strk;
On Fri, Jun 18, 2010 at 11:26:35AM +0200, strk wrote:
> I've started hand-crafting PHP bindings for the GEOS C-API.
> Currently in the process of merging into trunk for proper
> build scripts.
> One obstacle I found is that -ansi, which is added to
> CFLAGS by ./configure, won't accept Zend (PHP engine)
> headers, so that switch must be removed when building
> the PHP module.
> Does anyone know how to override the cflags for just
> one dir ? Or ideally, only drop the -ansi switch ?
> Here's the relevant annotation from configure.in:
>   2533    mloskot AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ansi], [dum
> my_cv_ansi], [-ansi], [], [WARNFLAGS="$WARNFLAGS -ansi"], [])
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   http://strk.keybit.net/services.html
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
