[geos-devel] [GEOS] #353: GEOSInterpolate segfaults
GEOS geos-trac at osgeo.org
Sat Jun 19 08:19:06 EDT 2010
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  3.2.1
Component:  Default     |     Version:  3.2.0
 Severity:  Unassigned  |    Keywords:
 When calling GEOSInterpolate against a POINT geometry (C-API), a segfault
 happens. See #283 for when that code was added.
 NOTE: milestone should be 3.2.3 but doesn't exist.
 Also, versions 3.2.1 and 3.2.2 should be added to trac.
 Also, r3012, r3013, r3014 and r3015 should be back-ported to 2.x branch.
Ticket URL: <http://trac.osgeo.org/geos/ticket/353>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
