[geos-devel] Polygonizer bug ?
strk
strk at keybit.net
Sun Jun 20 04:16:03 EDT 2010
Martin, I'm adding a testcase for the Polygonizer using example from :
"JTS Developer's Guide, Chapter 6 - Polygonization"
Here's the input, represented as a collection:
GEOMETRYCOLLECTION(
LINESTRING(0 0, 10 10),
LINESTRING(185 221, 100 100),
LINESTRING(185 221, 88 275, 180 316),
LINESTRING(185 221, 292 281, 180 316),
LINESTRING(189 98, 83 187, 185 221),
LINESTRING(189 98, 325 168, 185 221))
When passing it into the Polygonizer class I get
2 rings, no cut or invalid edges and 3 dangles. Also notable is that of the 3 dangles, 2 are identical
and specificall are the isolated edge (first geometry
in the collection).
The example in the guide suggests the rings should
be 3 instead, and that there should be one cut
edge (represented in blue) and 2 dangles
the red ones.
Does it sound as a bug in GEOS or does JTS give the
same results ?
Note that forcing proper noding using the union trick
does give the 3 expected rings, but still lacks the
cut edge and duplicates the dangle.
Thanks in advance.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
