[geos-devel] Re: linearref::LinearIterator segfaults
Martin Davis
mbdavis at refractions.net
Mon Jun 21 12:06:12 EDT 2010
Thanks, strk.
I added a check in the LinearIterator constructor:
* Creates an iterator starting at
* a component and vertex in a linear {@link Geometry}
* @param linearGeom the linear geometry to iterate over
* @param componentIndex the component to start at
* @param vertexIndex the vertex to start at
* @throws IllegalArgumentException if linearGeom is not lineal
public LinearIterator(Geometry linearGeom, int componentIndex, int
vertexIndex)
if (! (linearGeom instanceof Lineal))
throw new IllegalArgumentException("Lineal geometry is
required");
strk wrote:
> Doing tests for the PHP biding I found a segfault
> when using the C-API GEOSProject method against
> something which is not a lineal geometry.
> This goes down to linearref::LinearIterator assuming
> the input is a lineal geometry w/out checking.
> The bug goes deep into JTS as well, where you don't get
> a segfault but do a wrong assumption here:
> private void loadCurrentLine() {
> if (componentIndex >= numLines) {
> currentLine = null;
> return;
> currentLine = (LineString) linear.getGeometryN(componentIndex);
> That is, there's no code checking that 'linear' is a LINESTRING
> or MULTILINESTRING:
> public LinearIterator(Geometry linear, int componentIndex, int vertexIndex) {
> this.linear = linear;
> numLines = linear.getNumGeometries();
> this.componentIndex = componentIndex;
> this.vertexIndex = vertexIndex;
> loadCurrentLine();
> I'd throw an IllegalArgumentException from the constructor, if geom
> is not LINEAL.
> Will do this in GEOS trunk, but wanted to signal JTS too...
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
